November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-22-2005, 12:02 PM
James Baldwin's Avatar
Subsistance du serpent
Send a message via Skype™ to James Baldwin
Default Need Recommendations for Exhaust Fabrication in Dallas ???
The Shelby headers simply are not going to work. They are hitting the steering shaft and the frame support on one side and I would have to pound a dent about 1/2 into 2 tubes to get them to align. On the passenger side, they are 3/4" too far forward meet the holes in the body.
Does anyone in the Dallas area know of exhaust system fabricators would will help custom fit my headers?
Thanks
James
Old 04-22-2005, 02:31 PM
Bud Man's Avatar
Cobra Make, Engine: Former Owner/Builder of KMP142 427 Sideoiler, Tunnel Wedge, Aluminum heads, etc.
James:
You have mail....
Bud
Old 04-23-2005, 07:27 AM
Cobra Make, Engine: specialty motor car (out of existence) 351w 405 hp. c6 auto.
James,
I don't know what engine you have, but on some engines the exhaust ports are staggered from side to side. Are you sure you have the right header on the right side of the engine. Mine are different from side to side. Just food for thought.
I don't suffer from insanity, I enjoy it.
Bob Taulbee
Old 04-24-2005, 03:58 PM
check with the people at lone star classic ,they can build you just about anything you need
Old 04-24-2005, 08:41 PM
Cobra Make, Engine: ERA #122 (Sold) : Ford GT #484 Heritage Edition; 2008 GT500 Red/Black
Ummm...yea you deal with him alot.>Rob does headers all the time.
Matt
2006 Ford GT #484 Heritage Edition
2003 Hummer H1 OpenTop
2003 Hummer H1 Wagon
Old 04-24-2005, 09:07 PM
ItsOnlyMoney's Avatar
Cobra Make, Engine: Ford GT
Originally posted by 427Aggie
Ummm...yea you deal with him alot.>Rob does headers all the time.Matt
Rob even fixed Matt's "penetration" problem
Header to sidepipe penetration that is
David
Old 04-25-2005, 06:59 AM
392cobra's Avatar
6th Generation Texan
Is Matt going to start replacing "Smiling Bob" on the Enzyte commercial ?
Old 04-25-2005, 08:04 AM
Bob,
Yes, these only fit one way. If you try to put them on the opposing sides, the pipes don't clear the footbox. thanks though
Matt,
Thanks for the info. He must be good because we have all heard how bad your "penetration" problem was...
James
Old 04-25-2005, 10:31 PM
James isn't the Shelby aluminum body you have the same as the Kirkham body? If so why wouldn't the Kirkham headers work? Just give me a call and we would be happy to build you a set. We have done several sets for FE and small blocks because most do not fit or they are to small. Thanks, Rob & Keith
Keith C
Old 04-27-2005, 12:24 AM
Cobra Make, Engine: KMP329 w/KC489 Shelby
James,
The headers go around the steering shaft, so I don't know what is going on there, but the 427s usually need to be dented to clear the frame or footbox depending on which headers you get. Contact the Kirkhams.
Old 04-27-2005, 07:41 AM
Because of the angle of the curve, the pipe will have to be dented about 1/2" on each side to get the primary to line up with the Sidepipe.
The bigger issue is the paasenger side. The pipes are about 1" too far forward.
James
Old 04-27-2005, 11:37 AM
Specialk's Avatar
Cobra Make, Engine: 427 SC
Send a message via AIM to Specialk Send a message via Skype™ to Specialk
James,
I usually have to play around with the headers for quite awhile to make them fit. It usually involves creative cutting and welding.
Keith has an excellent point, why not buy a set of Kirkham headers. They come out of the box fully welded and fitted, and they do fit! You should be able to use your Shelby sourced sidepipes, or the Kirkhams if you wish. The Kirkham sidepipes look original, but are much louder than the Shelby pipes.
kris kincaid
Old 04-27-2005, 12:13 PM
Cobra Make, Engine: SHELBY GT500...slightly modified. Former owner of CSX4758..a GEM of a ride!
Kris.....I have CSX4758 and trust me the Kirkham pipes don't even come close as I borrowed a set just to see if I could save some time. Mine have been adjusted to fit by Rob.....but now that my car has been back to Shelby some major adjustments I'm wondering if they will fit now especially since they have been welded up solid.
Gary
Old 04-27-2005, 12:34 PM
Specialk's Avatar
Gary,
There are slight differences between a 'glass car and an aluminum car. That 3/4" tube that James tubes are touching is placed differently in a 'glass car. The motor mounts are also different.
I have never had any problems with the Kirkham headers on a Kirkham aluminum car. Maybe these cars are so different that nothing will work out of the box.
kris kincaid
Old 04-27-2005, 01:08 PM
Sorry Kris...my bad. the last Kirkham that was finished here in town the guy had to take a hammer and flatten out the pipe where James is talking about to make it fit. From what I hear Shelby is quoting 6 weeks just for a new set of headers which is really out of whack. I still say if ERA, Superformance etc....can furnish welded up headers that fit then Shelby should be able to do it also rather than putting this rather expensive procedure off onto the customer....but then that's just my .02. Thanks for your input and help in other areas.
Gary
Old 04-27-2005, 01:54 PM
Send a message via AIM to jpfletch1 Send a message via Yahoo to jpfletch1
The Kirkhams won't sell you just the headers. If you want S.S side pipes you have to buy their whole system. Bogus
Old 04-27-2005, 02:02 PM
John A. Simpson's Avatar
Cobra Make, Engine: KMP 393 $27 S.O. bored and stroked to 482
Default Keith Craft
Do I understand you correctly, you build headers/side-pipes for Kirkham and CSX cars? I thought that a 2" primary pipe might be too small for one of your 482 monsters with the Stage 2 Edelbrock heads. Do you ever make your side-pipes with a merge collector instead of the traditional style? I think I saw merge collectors on Dick Smith original Cobra. What is the approximate cost?
Sideways
Old 04-27-2005, 02:04 PM
R U YELLA's Avatar
Ed Digges
Cobra Make, Engine: Kirkham #328 w/ 390FE
The header pipes from KMP are exactly the same as the ones from Cobra Restorers. The only difference in the headers are the 5 & 6 pipes are reversed vertically. There are 2 different side pipes from CR. The ones that have "Made in Canada" are the same ones as the KMP's.
Is your car a CSX or KMP? If it is a KMP and you had them do the side pipe cutouts then you need to get the KMP headers & side pipes. They cut the holes according to their pipes they supply.
