Old 05-08-2008, 08:21 AM
SSSammy's Avatar
Default Windshield glass replacement in DFW area?
Has anyone found a source for the Cobra windshield glass? ERA does not have one in stock at the moment so I am exploring other options. This is the generic English frame, I believe. But I am wondering if one can be cut from flat DOT glass. Ideas?
Sam
Old 05-08-2008, 08:37 AM
Try Finishline (finishlineaccessories.com), bethania-garage.com, and cobra restrorers. There are also a couple vendors that sell Cobra windshield glass on ebay.
Old 05-08-2008, 10:04 AM
392cobra's Avatar
6th Generation Texan
Sam,
Sorry to read of your broken windshield.Really Sucks.
Have you tried Lone Star Classics ?
I have no idea if they are the correct size or not,worth a call though to find out.
Old 05-08-2008, 10:11 AM
Cobra Make, Engine: Backdraft 427 Stroker, Sterling Gray/Silver
You may want to consider Lexan. The cost is nearly the same as glass and you won't have any more cracks or major rock chips.
Old 05-08-2008, 10:37 AM
Joe Wicked's Avatar
Sorry to hear that Sam. What happened? That is one that I cannot show up with my Multimeter and trace down.
Why do they call it "Common Sense" when it is so rare?
Old 05-08-2008, 02:39 PM
SSSammy's Avatar
Default The sad story :(
The guys that went to AER last Sat already heard this .. let this be a lesson to those with 4 post lifts:
The Cobra (Dirty Sally) has been sleeping in the top bunk. When I went to get her down so I could do some detailing prior to the AER Show, the emergency rip cord toggle for the garage door opener was caught between the sunvisor and the window frame. I did not see this and was not looking up as I let the lift down. The tension on the cord pulled the window frame apart and cracked the glass before it let go. I am sure most of you know how that felt Anyway, I disassembled the window frame, took the glass out and then pounded the frame back into shape with a rubber mallet, using the granite kitchen counter and newspapers for a cushion. Put it all back together and it is functional. Big diagonal crack from the sun visor mount to the lower left corner.
Thanks all for the suggestions on sources. Fred, I was eyeballing the Lone Star cars at the show and they seem to use a slightly taller windshield. I'm not positive. So I will probably start with Cobra Restorers .. he has done some ERA cars, so he might have an idea if I am really generic.
I know a bunch of Cobras are using Lexan, but I will hold off as I am concerned about our recently more strict annual inspections in TX.
Sam
