November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-28-2008, 07:42 PM
Cobra Make, Engine: Superformance, 351W with 400 H.P.
Thanks Macgyver
I did not try that; maybe that is why it keeps leaking. I'll try that when I put it back together.
Old 08-28-2008, 09:23 PM
MacGyver's Avatar
Cobra Make, Engine: B&B 5.0 roller W/carb & T-5 WC
I have fought that battle before only to discover the leak was around the bolt threads. This can happen on t-stat housings as well as front cover and water pump bolts. Be very carefull and check front cover and water pump bolt threads as they can be a bottom casting for the bolt hole causing a hydrolock of sorts breaking the casting when bolts are coated in areas when the hole bottoms out instead of penetrating a hollow. A friend of mine recently broke a chunk of his block off using too much sealer in an area where it wasn't needed. i recommend probing the casting with a pick first. If the hole bottoms out you shouldn't need sealer. If it penetrates into into a water jacket you should definatily seal the threads. A thin coat on all bolts should ensure a good seal regardless.
"Oversteer is when the passengers are scared. Understeer is when the driver is scared."
Old 08-28-2008, 10:08 PM
I may have your best answer. I had this same problem this week. I called two different auto parts stores - they had the same question for me, and the same answer for the solution - which has worked. Check this out -
They asked - is you water outlet chrome? I said - why yes it is.
They said it's warped.
I said - it has only 4000 miles on the new engine.
They said - no mater - it's warped.
In disbelief, I removed it and put it on the counter - yep warped.
I installed a plain old cast iron water outlet - and all is fine.
Don't bother with fancy gaskets, or messy glue/sealer - just get a plain cast iron water outlet (paint it if you want) and problem solved - forever.
