Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Thor Motorsports (TWM Induction)
Old 09-05-2008, 01:05 PM
thorconstr's Avatar
Cobra Make, Engine: ERA 427" 351W
Default SEMA input
Once again TWM has a booth a SEMA. What do you think will appeal to people this year? Polished units, powder coated units, combination powder and polished, plain, or all of the aforementioned? Thanks in advance, Al
Al W.
Old 09-05-2008, 02:26 PM
marcalan's Avatar
Cobra Make, Engine: era 289 FIA #2112
my preference would be plain, however, a powdered unit with a color that catches the eye of people walking by would probably bring more to the booth
live for the moment or it may pass you by
Old 09-05-2008, 02:35 PM
Kramer's Avatar
Cobra Make, Engine: ERA 739
Polished always looks nice in this crowd. Powder coating can look good if the colors are matched and coordinated in a nice fashion. Lots of folks are always wondering about filer applications for street use...might be good to addresss that issue as well.
Old 09-05-2008, 02:36 PM
thorconstr's Avatar
That's my thinking, thanks for the viewpoint.
Al W.
Old 09-05-2008, 02:57 PM
Seems to me that SEMA is about over the top eye candy, at least to get them in the booth and to show what CAN be done with your product. I think it is also good to have some of your stock stuff to show what comes out of the box... That said a full polished setup with some bright, colorful coated
accents would be just the ticket in my mind.
Joe Weight
The Ultimate in Aluminum Bodied Replicas
Old 09-05-2008, 03:09 PM
thorconstr's Avatar
Thanks for the help!
Al W.
Old 09-05-2008, 04:22 PM
Cobra #42's Avatar
Cobra Make, Engine: Superformance Roush 427
Default SEMA Display
Are you going to have a Cobra in you booth? Or any engines on stands. Just an idea. db
Don Barnes
Driving Instructor
texasdrivingexperience.com
Texas Motor Speedway
Old 09-05-2008, 04:58 PM
Default You need and outside spot
thorconstr Al I know this is not cheap but there is nothing like showing people how well your system works. I real car run, Give the specs on the motor,with a .650-750" lift cam, 10.5- 11.0 compression on pump gas. Have the idle at 850-950 rpm and then tap the throttle and show the instant responce. A dyno sheet of your system against any carb. There is a power different between stacks and a carb in the mid range, more power and torque. Tell them the system is not for 8,000 rpms and makes more power in the lower to middle rpm range. Drivability and mpg is the hook. Show your 4 best selling systems in different stages from natural look to coated. A nice picture blown up of Fred Kemmers motor wouldn't hurt to show the WOW look. The bottom question is WHY should I buy your setup over a carb??? Answer Power, drivability, and looks.This is about having the best for your car. Not about saving pennies and going cheap. There are no carbs on new car anymore. Not saying that the lastest carb are not very tunable. Would you rather pull apart a car on the hot motor and possibly have a fire or just go to the laptop, change a couple on numbers and you have a whole new running motor. You can even do this driving down the road. Can't adjust a carb while driving at 50 mph. The rest is on you Al. Rick L. ps lost the number for getting the screens on the throttlebodies. Will get back to you after R&G. Ps is anyone running with the IAC block? how is that working out??
Old 09-06-2008, 10:23 AM
thorconstr's Avatar
I think a lack of space keeps TWM from doing an engine for the show, but that is a great idea. The IAC is working well. Rick, do you want horn top or horn base screen filters?
thormotorsports1@msn.com www.thormotorsports1.com
Al W.
