Go Back   Club Cobra > Club Cobra Tech Areas > Tires and Wheels
Old 02-12-2010, 07:45 AM
JCoop's Avatar
Default Fender liner for stone protection...
I put on a new set of Nitto 555 tires and they are fantastic! However, they DO kick up a ot of stones and debris, especially around here: dirty New York streets. Almost as much as the Good Year hand-cut slicks. I remember putting on adhesive-backed liners under the fenders of my old SB SPF Cobra, and also used sound-deadening material under the fenders of the GT40; but I have some-ziemer's and can't remember what/where I got them. Does anybody have new information, or know of what's available at home depot, etc. that I can use? Shelby and Hillbank doesn't stock them anymore either. Thanks!
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
Old 02-12-2010, 08:04 AM
CBattaglia's Avatar
Cobra Make, Engine: Gary Edwards Racing 460
I believe the new SPF's have it standard now. Maybe they sell after market packages if you didnt want to fabricate something. I have read nightmare stories about installing that stuff.
Where in NY? Im 60 miles N of NYC.
Its not the will to win that matters....Everyone has that. Its the will to prepare to win that matters.
Old 02-12-2010, 08:36 AM
Banned
Ray, I went to a local arts & crafts store and bought 11x14 sheets of black 3/32" neoprene. Then started at the top of each wheel well using a full sheet, attaching with contact cement. Then patchworked to the edges, using a razor blade for exact fit. Once you have the panels in, then mask off and hit it with 2-3 coats of black rubberized truck bed liner/undercoat. Looks pro and works great. Takes a little time per each wheel well but I spread it out over a couple weekends (did the rears first and then the fronts).
I've done much harder projects...this is one of those that I'd do again if I had to. It's just a little timing consuming and you have to work upside down.
-Dean
Old 02-12-2010, 09:47 AM
noblec5's Avatar
Cobra Make, Engine: FF Daytona Coupe #211, SPF,1037 sold
I bought mine from Jeff Balsamo from CobraFormance, and installed them over the summer. The neoprene is already pre-cut. Jeff's also a forum member. I have the Goodyear "Billboards" and they pick up boulders it seems like. Bit no worries with Jeff's neoprene!
His number is 650-678-7711 (cell) or hallbalsracing@comcast.net
Respectfully,
Chris
Old 02-12-2010, 10:35 AM
Silverback51's Avatar
I used a gallon of Herculiner bedliner material. I was able to get 6 coats applied from the gallon of material that I had. I run the GoodYear Billboards and have not had any issues.
I forgot to mention. It took about a short case of beer to apply also.
John Hall
Old 02-12-2010, 10:58 AM
Bob In Ct's Avatar
I bought 4 precut neoprene pieces for my SPF a few years ago. It's still on! It's pricey, but good stuff. Lots of prep but the liner went on easily using a 2 inch paint roller.
Contact Craig Hill at "King of the Hill". 925-449-3330
Old 02-12-2010, 12:19 PM
JCoop's Avatar
Nah, I called and they don't stock the part.
I'm in Long Island...easy 'nuf for a spring coffee meet : )
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
Old 02-12-2010, 12:25 PM
JCoop's Avatar
-Dean
Dean, your projects are always so involved but always look great, I'm sure. We don't have the luxury of Ca weather so even though I have an old oriental under the car, it's still too cold to be on my back that long, hehe.
I do think neprene is probably the best stuff to use. Thanks!
Ray
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
Old 02-12-2010, 12:35 PM
JCoop's Avatar
No answer Bob...
and the case of beer will certainly help, Silverback.
I'll call Jeff, Chris. Thanks.
I got one of those spider cracks on my previous SB SPF, and they ain't easy nor cheap to fix. It was easier to put a novice stripe over it
Thank you all for the replies. Time to get busy. Cabin fever real bad...
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
Old 02-12-2010, 03:22 PM
Ray, the padding kit i used was from kirkham it comes with a templet to cut out the padding, you may have to alter as i did to fit you car. I used contact cement as they recommended.It works great and they are great people to deal with....
