06-18-2011, 03:01 PM
nc
Cobra Make, Engine: 65 Backdraft Cobra 347 with webers
xxxxxxxxxx
Reason: xxxxxxxxxx
06-18-2011, 04:18 PM
IN
Cobra Make, Engine: ERA 838
live axle or independent?
06-18-2011, 04:19 PM
What do you mean by "outer bottom edges"? Only the outside edge on both tires?
06-18-2011, 04:33 PM
Super Moderator
Obviously, you need to do burnouts...it evens out the wear so they'll be slick all the way across.
Are you sure the inner edges aren't worn too? If they are...underinflated.
If not, and it's an IRS (assume it is given it's a Backdraft)...get it aligned.
Jamo
06-18-2011, 07:06 PM
wa
Either to much positive camber, or the toe in is off. Or it could be a combination of both.
John Hall
06-18-2011, 07:56 PM
tx
Also, I would get down and take a look at your car from the rear. If you can clearly see that your tires are towed in, try lowering your suspension. If your coilovers are adjusted way too tight, you will wear the outsides of your tires.
" It ain't no big deal"
06-18-2011, 08:03 PM
OR
Center of tire=over inflated, Both outer edges=under inflated, One edge or the other or uneven wear across the tread is an alignment problem.
ERA FIA 2088
06-18-2011, 08:15 PM
Cobra Make, Engine: FFR from Levy Racing 302 FI w/Edelbrock Performer heads
Yeah got to go with under-inflated.
dave from mesa
Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes. Finally got around to going to the VA.
06-18-2011, 08:25 PM
tx
Underinflated tires will wear on the inside AND the outside of the tires.
06-19-2011, 10:39 AM
MO
Cobra Make, Engine: Sold ERA FIA 2139, 331 Weber IDF
400 miles and bald on one of the edges on both the tires (that what I get from the post) sounds like a terrible alignment issue.
06-19-2011, 02:17 PM
nc
Hey guys Thanks. I am going to get an alignment done. Just hope that corrects the problem. It is only wearing on the outside bottom of both rear tires. Rest of rear tires looks great. Running around 30lbs in tires. Got to get the wear problem solved before I get two new tires as they are not cheap.
06-19-2011, 02:31 PM
wa
Don't be surprised if you have to buy new tires so they can do an alignment.
John Hall
