Go Back   Club Cobra > Club Cobra Tech Areas > Tires and Wheels
Like Tree1Likes
  • 1 Post By saltshaker
Old 12-17-2012, 04:24 AM
Default Removing spinner on PS&E wheel
How do you get the spinner off...?
Jon
Old 12-17-2012, 05:08 AM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
You could call them. 310 534-4477
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
Old 12-17-2012, 06:15 AM
Thanks, but they are out of bussiness
Jon
rcobrakit67 likes this.
Old 12-17-2012, 08:38 AM
DonC's Avatar
Jon:
If they are pin drives you should use a lead mallet (about 6 lb.). Remember that the passenger side is probably reverse threaded. Also don't keep hitting the same spinner ear as you loosen them. Rotate the wheel to bring the ears into position to hit them.
DonC
Old 12-17-2012, 08:53 AM
dcdoug's Avatar
Assuming they are pin drives, the spinners will rotate in the direction of the front of the car to come off. So the driver side remove by spinning them to the left (counter clockwise) and the passenger side to the right (clockwise).
Here's a video that might help: https://www.youtube.com/watch?v=X8kCWG3d1Cc
www.partskeeper.com
Old 12-17-2012, 09:01 AM
Cobra Make, Engine: FFR Mk III 427w, dual quads
If you mean PSE, just grab hold of it & pull it off. They're held on w/a pair of O rings. They're decorative spinners.
HTH,
Will
Old 12-17-2012, 11:02 AM
With the car parked with its rear facing a telephone pole, jack up the rear of the car so both wheels are off the ground. Carefully chain the bottom pointing ear of the spinner on each wheel to the telephone pole. Then, lightly gun the engine with the transmission in reverse gear. Both spinners will come right off.
Old 12-17-2012, 11:04 AM
HTH,
Will
Yes, but my way will still work, even on decorative spinners....
Old 12-17-2012, 01:22 PM
Thanks, their off...
Old 12-17-2012, 02:24 PM
Cobra Make, Engine: FFR: 302 w/aluminum heads, Edlebrock injection. Street car trim, no scoop, side pipes or rollbar.
Send a message via AIM to Maricopa
Thank God for useless posts. If people only responded when they actually knew the answer this place would have closed up months ago.
"Cobra-Cobra-bo-bobra, banana-fanna-fo-fobra, fe-fi-mo-mobra...Cobra!"
Old 04-08-2013, 08:01 PM
I/m trying to off the lock. But are extremely hard to off. Inclusive I design special tool to try disamble the wheel, but are very, very hard. The otehr issue that I have is that my wheel are powder coated paint in black color and if I use the hammer I will damage the lock nut. Do you have any idea how can remove the lock from wheel. Thankjs
Old 04-24-2013, 11:45 PM
I don't know if that brand of spinner hub wheel is any different than any other brand, but I used to get the spinners off my Superformance by just hitting them with a lead hammer. A little trick to keeping the spinners in great shape, and also keeping your hammer free of deep gouges, is to buy some vinyl tubing (Don't remember the specific ID) and cut it into about 4" or 5" lengths. Slide it over the spinner arm, and hit the vinyl instead of the steel or aluminum spinner itself. Works great, and each piece of vinyl lasts about 4 or 5 times before needing to be replaced with new.
