Go Back   Club Cobra > Club Cobra Tech Areas > Tires and Wheels
Like Tree3Likes
  #41 (permalink)
Old 12-29-2013, 06:29 PM
Cobra Make, Engine: Compomotive. 351w, close ratio four speed, live axle, 4wdb.
Default Mt
RetCop,
I am looking for 2
26x10x15 tires.
Still available and can you ship?
Tinman
  #42 (permalink)
Old 12-29-2013, 06:44 PM
Cobra Make, Engine: ERA #440 66 427 FE sideoiler Top loader 4 speed
Default Tires
Same tire dilemma for me, shure like the G Y B Bs look. The M Ts sound interesting also.
  #43 (permalink)
Old 07-15-2014, 11:32 AM
Here are my new Coopers. Pretty much the same as the MT's that I can tell from all the technical data. The black side and the white letter out sides have different designs. I prefer black walls, so I got a cool Cobra snake...
295/50/15 in the rear and 235-60-15 up front
  #44 (permalink)
Old 07-17-2014, 07:33 AM
motordean's Avatar
Cobra Make, Engine: Superformance with Roush 427 R
I have the goodyears and they are horrible. I wish I would have gone with the Avons for traction purposes, but the look is just not there....
  #45 (permalink)
Old 07-17-2014, 04:02 PM
DanEC's Avatar
There you go again - splashing those great pictures of that beautiful ERA around so we can drool over them some more.
I have MTs on my ERA - basically the same tire but without the classic Cobra snake on them.
  #46 (permalink)
Old 07-20-2014, 09:01 PM
Cobra Make, Engine: Superformance No. 1359 / 351
Others with MT S/R tires have mentioned air pressures of 24lbs up front and 26lbs in the rear. Are these the ideal pressures for these cars?
Thanks in advance for your input.
Jamie
  #47 (permalink)
Old 07-21-2014, 08:04 AM
Shootnride's Avatar
Cobra Make, Engine: Superformance, 427SO
Jamie
I run 24 psi front and 20 psi rear on mine. Seems to work well for me.
Ted
  #48 (permalink)
Old 07-21-2014, 09:56 PM
Ted
Running the M/T SR's.
Last time at Willow Springs dropped the pressures from 24 front/26 rear down to 22 front/20 rear.
At the higher pressures the front end would hunt in/out when cornering hard.
Lower pressures it settled down and seemed fine.
Pete
ERA 289 #2027
  #49 (permalink)
Old 07-22-2014, 08:24 PM
Pete
Pete,
Are you back to 24 front / 26 rear back on the street?
Jamie
  #50 (permalink)
Old 07-22-2014, 08:50 PM
Pete,
Jamie
Glad you mentioned it...yes...I put them back up about that ~24/~26.
Reminds me to try the fronts at higher pressures to make it easier to park.
When the car isn't moving turning the steering wheel is a bit much these days with bad shoulders.
Pete
ERA 289 #2027
  #51 (permalink)
Old 07-22-2014, 09:51 PM
MaSnaka's Avatar
I'm running Ets and find the opposite pressures to work best. 24 rear and 26 front. Too much in the back and it gets loose easier. Too little and it gets sloppier. The fronts like a bit more pressure like Pete mentioned the steering is much nimbler and easier at slow speed. This is street driving only.
