28Likes
06-19-2016, 10:06 AM
Cobra Make, Engine: Superformance #705, Ford Racing 460 - 514ci
In my previous posted I stated the 2" vintage standard vintage tire kit.
06-19-2016, 11:54 AM
Senile Club Cobra Member
Originally Posted by fordracing65
I was 4 years old in 1980. Lol
I have underwear older than you.................
rick@autoventureusa.net
06-19-2016, 02:49 PM
Ne.
Kevin
06-19-2016, 07:13 PM
WA
Cobra Make, Engine: FFR Mk4 Roadster, LS3, TR6060, 8 3/4"
So you are recommending 2" for 17" tyres? On your car it seems like they are 15" wheels ...
Tim
FFR Mk4 Roadster
HSV Clubsport R8
06-19-2016, 08:07 PM
I would not do billboard lettering with 17" wheels
06-20-2016, 01:52 AM
1"is about the same size as my toyo lettering.
I think that's what I will take
2" is good for the back as the tyre wall is higher.
But I don't know if it will look good?
06-20-2016, 10:20 AM
OH
Cobra Make, Engine: ERA 714
I did mine this weekend. Pic below.
Phil
06-20-2016, 04:00 PM
WA
Phil
Is this the standard height version on 17" rims? Looks great !
Tim
FFR Mk4 Roadster
HSV Clubsport R8
06-20-2016, 05:11 PM
Ne.
With side pipe exhaust blowing on the tires & letters, how do the stickers hold up to that and cleaning ?
I use like Dove dish soap or tire cleaning sprays, will they cause harm ?
Kevin
06-20-2016, 06:55 PM
OH
I just put mine on so I am not sure how they will hold up. I think I would like them dusted up a little. Mine are standard size on 15" Mickey Thompson SRs.
Phil
06-21-2016, 09:46 PM
Cobra Make, Engine: Contemporary Classic 289 FIA
Billboard Letters
The bright white will fade which is good. They are adhered on for good and will not come off if applied with the adhesive provided when washing. Mine have been on just over one year now and actually I think look better as the brightness has faded which looks more "original" in my opinion.
06-24-2016, 03:21 PM
Cobra Make, Engine: Hurricane #1037, 351C, TKO 600
They look good. I just ordered a set.
Gregg H
Former TCC President
"Not the victory but the action. Not the goal but the game. In the deed the glory."
06-24-2016, 06:49 PM
Originally Posted by FUNFER2
No.
I wear CLEAN, old underwear.
D@mn kids....get off my lawn!
06-25-2016, 01:10 AM
Neutral
Something a little more traditional....
06-28-2016, 06:59 PM
TN
I will be installing my Tredwear Lettering this weekend. Question...did you clean the tire with degreaser only where the letters will be applied or the entire face of the tire? If you cleaned partial tire, I assume you applied tire dressing when complete. If so, did the finish look even between the areas that had been cleaned and not cleaned. I haven't been using tire dressing as I understand some dressings can be harmful to tires. I prefer the look of a clean tire over shiny dressings.
06-29-2016, 05:24 AM
OH
My tires were new so they were pretty clean. I just wiped them down relatively clean with a tire cleaner and went from there. In your case, I would just use hot soapy water, I don't think they have to be spotless.
Phil
06-29-2016, 05:27 AM
NJ
Cobra Make, Engine: SP0703 Ford 460 CJ
Pman1961,
Even though my tires were brand new, I cleaned the entire sidewall of the tire 3 times with Spray Nine and a stiff scrubbing brush. After using Spray Nine, rinsing with water and then drying, I used rubbing alcohol on the tire and mounting side of each Tredwear letter. If I recall correctly, Tredwear does not recommend using tire dressings on the letters so I have not used dressings on my tires since I installed the letters.
06-29-2016, 03:53 PM
TN
Thanks guys!! I'll report back when completed.
07-02-2016, 10:33 AM
Highly reccomend no matter what period correct says.
Oh the tires are Avons which are fantastic. Took em to the track and they were nice and sticky for a DOT tire. Only thing next is to get a red vinly wrap over front rear fenders because they kick up everything.
12-08-2016, 03:36 PM
Cobra Make, Engine: SPO 963, 351W
Anyone paint their letters on? I don't want stickers, so I got a paint stencil kit for mine. What paint have you used with success?
