Go Back   Club Cobra > Club Cobra Tech Areas > Tires and Wheels
Like Tree7Likes
  • 5 Post By Mark IV
  • 1 Post By keeptryn
  • 1 Post By Danr55
Old 01-06-2019, 11:25 PM
Default Avon cz66
Hi,
Can someone tell me how many miles these tires last in road use?
Old 01-07-2019, 06:39 AM
Sledge's Avatar
Cobra Make, Engine: BDR #168 427W 69+K miles and counting
BLemming:
You should be able to get 6000-8000 miles out of them on the road, if you avoid massive burnouts. Proper tire pressures are critical to keep the wear even across the tread surface. My front tires usually last a bit longer than the rears...
Bill
"If your work speaks for itself, don't interrupt"
Old 01-07-2019, 09:32 AM
Senile Club Cobra Member
We know of customers who have gotten as much as 14,000+ miles on them, no track days and reasonable street driving.
Look at it this way, how many miles do you drive the Cobra per year? Divide the Avon cost by six so long as you are 2000 per year. Figure that as your annual cost of tires. I would not keep them on more than six years due to aging and durometer hardness increase due to age and ozone. So if you drive more than 2000 miles per year adjust the calculation. Regardless, you come up with a few hundred dollars per year for the best available street LEGAL tires and the performance and safety they bring to the party. Your annual cost will be in the $300-400 range, a figure that you can budget. If you drive a high performance car you need high performance tires. That simple.
rick@autoventureusa.net
Old 01-07-2019, 11:10 AM
Hi all, Thanks for the comments.
I post this question because of the racing tires and I had no idea of how many miles can be ridden on the street with it.
I drive about 6000 miles a year so i have to replace a set of rear tires per year and a set of front tires every two years?
Old 01-07-2019, 11:20 AM
Hi Mark IV,
At this moment i have 17” Wheels with verry sticky tires.
But for my next project I would like 15” wheels because of the old scool look.
I don’t want cheap tires as i do wan’t performance
Old 01-07-2019, 04:11 PM
You have brought up an interesting question. If Wanting performance a requirement, are 17 " tires better than 15" tires? Regardless of cost, which performs better is my question. Did not mean to hijack but it seems the answer could make a difference. I do not have enough hands on knowledge to determine.
Old 01-07-2019, 08:47 PM
Phx Mike's Avatar
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
I have 6K on mine in 2.5 yrs and they are probably good for another 5K.
Old 08-27-2021, 01:15 PM
Cobra Make, Engine: Factory Five Mk4, 347 ci, 415 hp
I currently have almost 13K miles on my Avons and expect at least a few thousand more miles out of them if not more. I have not done any track days, rarely do burnouts but do drive rather aggressively at times.
Blacklemming likes this.
Old 12-07-2025, 05:04 AM
Update: I replaced my rear Avon tires at 21,000 miles and my front Avon tires at 29,000 miles
Old 12-08-2025, 04:15 PM
Danr55's Avatar
I have 15" Cooper Cobras front and rear. The rear tires last about 35000 miles and the fronts an additional 6-8 thousand miles.
keeptryn likes this.
Dan in Arizona
CCX3209
