Go Back   Club Cobra > Club Cobra Tech Areas > Tires and Wheels
Old 03-01-2008, 08:38 PM
double ugly's Avatar
Default wheel bearing dust cover
This might be a good topic for the tire/wheel thread/tread.
Anyone have a good solution for keeping the dust covers on?
John
double ugly
Old 03-01-2008, 09:36 PM
LMH's Avatar
LMH LMH is offline
I wonder if that's why the original SC's used a center cap on the front wheels and nothing on the rear?
Old 03-01-2008, 09:56 PM
cobrajam's Avatar
Cobra Make, Engine: Contemporary frame, Midstates kevlar body, Aluminum Shelby 427, G-force T-5
Do not know if you can see much detail from the attached pic, but the Contemporary chassis I picked up had the pin drive hubs that were drilled and had a 'D' shaped pin to hold the centers on. Someone had discussed this on a thread a while back and still had some of the pins, but they would not be that hard to fabricate if you wanted to go that direction. I guess another option would be to drill and tap and use a counter sunk set screw like some use to hold the 'decorative' spinners on(?)
Old 03-02-2008, 07:02 AM
Rick Parker's Avatar
The outer end of the adapters have about 1/8-3/16ths of an inch without threads. One or more small set screws could be installed around the perimeter. Just be sure they are below the surface of the threads so the knockoff could be removed without the removal of the end cap if needed.
Rick
Old 03-02-2008, 07:08 AM
Cobra Make, Engine: ERA 427 SO
I was told that the originals didn't have the dust caps on the rear because there were no exposed bearings on the rear to protect from dust, so they left them off.
Ken
Old 03-02-2008, 07:16 AM
mr0077................You are correct.
Rick
Old 03-02-2008, 07:18 AM
computerworks's Avatar
So moved....
Old 03-02-2008, 07:33 AM
Would a little RTV around the O ring help? The covers pop off when the wheels are removed. Drilling the covers isn't an option though. No adaptors. They're 6 pin hubs.
John
double ugly
