SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 01-27-2010, 08:54 PM
lovehamr's Avatar
Stolen Avitar
Default TKO 600 assembly
Trans guys; a couple of questions if I may. I removed the input shaft from my TKO to get it machined a little and need to get it back in. Question #1, what lube do you use to keep the bearings in the proper place the back of the I/S while installing it? I'm assuming it's some sort of soluble grease. #2 How many of those little bastages (bearings) are there supposed to be!? I might be doing some more magnet fishing.
Thanks, Steve
Old 01-27-2010, 10:16 PM
Barnsnake's Avatar
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
I can't answer your question with a specific grease or roller count, but I would suggest you don't go "fishing" with a magnet. You'll magnetize any rollers you catch. That's not the place you want all of the metallic debris in the gearbox to end up.
A small amount of any petroleum-based grease should disperse into the tranny fluid without issue. If it's cold enough, Vaseline should work.
Jim
A Gnat! Quick, get a sledgehammer!
Old 01-28-2010, 04:03 AM
There should be 17 pocket bearings.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 01-28-2010, 05:37 AM
lovehamr's Avatar
Stolen Avitar
Thanks Brent.
Jim, I have no choice, some of them fell down in the trans as I removed the input shaft.
Steve
