Old 11-26-2010, 07:45 AM
Cobra Make, Engine: AC cox 2699 roadster Riverside FIA RSR2001
Default Browell bellhousing tool
I am about to fit a scattershield bellhousing and see Browell make a tool that makes aligning the bellhousing a whole lot simpler.
Anyone used it?
Ross
Old 12-31-2011, 10:42 PM
Cobra Make, Engine: Superformance aluminum427
Hi Go to hourbor freight an buy the magnetic base an dial indicator about 24 dollars, then cut the mast off to about 3 in. then grind a flat on bothsides where you can mount dial indicator. Its simple an cheap. If you need a pic of mine let me know. Flip
Old 01-01-2012, 09:05 AM
lovehamr's Avatar
Stolen Avitar
This shows a step by step using the Bowell tool on a chebby. Not cheap, but it looks pretty easy to use.
CRG Research Report - Bellhousing Alignment
Old 01-01-2012, 10:21 AM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Dial indicator works just fine.
Old 01-01-2012, 06:03 PM
Hello Ross
Took a look at this tool and it looks like it will make aligning a bell housing a lot quicker than using a dial indicator and magnetic base.
It's accuracy would be dependent on not having any dirt, nicks or dings between tool and flywheel crank mounting face
Best regard
Carmine
Old 01-10-2012, 01:25 PM
Carmine, which tool are you talking about? Do you have a link?
Old 01-10-2012, 02:06 PM
Hello Brewme
Im talking about the browell (bellhousing alignment tool)
Heres the link
Welcome to Browell Bellhousing
Old 01-10-2012, 04:01 PM
Will this work with any bell housing? I don't know which bellhousing I have, but as you can see from the picture I have a leak! Someone told me it is likely a misalignment, an overfilled trans., or a bad seal.
Could it likely be something else?
Old 01-10-2012, 08:03 PM
Default Tool
I just ordered the Browell tool, the only question they ask when you order is the opening for the transmission, for a Tremec its 4.850. It is exspensive, 135.00 plus shipping. Flip
Old 01-11-2012, 08:20 AM
crawleyscobra's Avatar
Cobra Make, Engine: Factory Five MKIII, 427W
Accidental posting...
Old 01-11-2012, 08:23 AM
Default Highly Recommend one...
I ordered one and used it. I had never aligned a bellhousing before and this method just seemed so much easier and accurate (the tool is designed to give you a .0025” runout). Take a look at my Transmission page on my web site to see how easy it was. If you have never aligned a bellhousing with a dial indicator and would not feel confident in your results I would highly recommend one.
FFR6682 - MK 3.1 complete kit, Forte built Ford Racing BOSS 427W(475hp/500lbs), TKO600, Power Steering/Brakes, VPM Front/Rear sway bars, Bump steer kit, SAI mod, 13"Front/11.65"Rear Cobra rotors w/calipers, Nitto NT05-255/40R17-Front, 315/35R17-rear,3.55 IRS.
Old 01-11-2012, 09:42 AM
135.00 browell bellhousing alignment tool is a lot cheaper and faster to use vs buying and using a dial indicator and magnetic base with swivel.
Old 01-11-2012, 09:46 AM
Probably should start a new thread on this...but about how long would it take a novice to replace a seal on a Tremec trans (3550)? I have a leak coming from where the trans meets the Lakewood bellhousing and the research I've done tells me it is likely the seal. Any advise is appreciated!
Old 01-11-2012, 09:57 AM
Default Tool
Its alot easier but it is not cheaper, I bought the dial indicator an magnetic base for 24 dollars verses 135 dollars plus shipping. Dial indicator is aggravating an takes 2 people operate. Waiting for my Browell to come, hope it works Flip
Old 01-11-2012, 10:43 AM
24 dollars for a dial indicator, thats cheap.
Is it made in china.
If it is then you get life time warranty and limited time reliability.
