SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
  #21 (permalink)
Old 01-02-2012, 03:07 PM
Jac Mac's Avatar
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Smile
I read where you have already had the top cover off, so it would be easier if you have it off while adjusting/checking both 1/2 & 3/4. Do the one on the side( 9/16"- for 3/4 shift - synchro hub @ front ), then do the one under the top cover ( 1/2 shift)---be careful not to drop the spring or grub screw in trans- although you should be able to just tighten it a bit further-- if you have one of the later trans that just uses a longer spring without the grub screw you can use a short rivet or round head screw that fits inside the spring coil to increase spring load---you would have torefit top cover temporarily or hold the spring/rivet/whatever you use down level with top face of trans case while you check shifter action. good luck..
Jac Mac
  #22 (permalink)
Old 01-02-2012, 03:44 PM
marcalan's Avatar
Cobra Make, Engine: era 289 FIA #2112
Thanks, I won't be able to try this till the coming weekend, I will report back then. Much appreciated.
live for the moment or it may pass you by
  #23 (permalink)
Old 01-04-2012, 01:12 PM
davids2toys's Avatar
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Try Mike Miles, he seems to know the Ford transmissions.......
BTW: Don't use synthetic oils in the toploader........... Kiss of death!
So what do you use? I have been looking and researching with no luck at all. All the makers of NON SYN, GL-4 have discontinued this product due to low demand...what a PITA!!!
  #24 (permalink)
Old 01-04-2012, 01:44 PM
Myth.
I've been kissing death for about 15 years. Redline MT 90.
Perfect shifts.
Chas.
  #25 (permalink)
Old 01-04-2012, 02:12 PM
I'll say.
  #26 (permalink)
Old 01-05-2012, 07:30 AM
Myth.
Perfect shifts.
This is the one product I have read might be pretty OK for the Toploader, and if I cant get the non syn/GL 4, I may have to use!
  #27 (permalink)
Old 01-05-2012, 08:41 AM
Originally Posted by davids2toys View Post
This is the one product I have read might be pretty OK for the Toploader,...
Which is why I use it and recommended you do too...
Chas.
  #28 (permalink)
Old 01-05-2012, 07:54 PM
I may have to!
