Old 02-03-2012, 04:39 AM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Question tremec transmission question?
when i built my 342 with mass flo fuel injection i used a tremec 3550 trans because i was running efi i used a vss sensor in the transmission to conncet the speedometer cable. on my 445 i will be running a carb what do you use to connect the speeo cable on a tko 600 and does it come with the transmission?.
Old 02-03-2012, 05:18 AM
Clois Harlan's Avatar
I assume you have an electronic speedo in which case you can just use the connection you already have but if not you can buy a speedo gear and mechanical cable from ebay (pink assuming 26" tires and 3.50 rearend).
It can accept either mechanical or electronic sensor. I have both a 3550 and a TKO 600 in my garage. Actually, you can get an app on your cell phone that will double as a speedometer if you like.
Seriously, you will be fine going to a carb.
Clois
"Let's roll"
"Be part of Something Good
Old 02-03-2012, 05:36 AM
i am running a autometer vintage cobra mechanical speedometer.
Old 02-03-2012, 06:22 AM
mreid's Avatar
There is a mechanical port on the driver's side for your mechanical speedo.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
