SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 03-30-2012, 12:32 PM
Cobra Make, Engine: #010 SC motorcars 428PI TKO600
Default tko stuck in 5th gear
Well I thought I would share my experince with you as to what happened with my transmission. We went for a nice Sunday cruise and on the way back about 10 miles from home I down shifte to 4th and run the car up and shifted back to 5th, everything was okay, pulled into the lot and could not downshift, it was still in 5th, even though I could move the shifter into other gear slots, it would totaly lock the trans down as it was in two gears at once, I could put the lever back into neutral and it was still in 5th, I could not get the trans to go to neutral as far as the gears were concerned. The shifter would go but it was stuck in 5th. Fast foward to Thursday nite, pulled the trans out.......whew.... disassembled the trans found that the 5th reverse shift rail had broken in half dropping shift pin down into the bottom of the trans and chewed up the reverse idler gear and cracked the bottom of the case.
I had talked to Mike Forte who sold me the trans new in 2009 about maybe it had a sheared shift pin or something I could fixed quickly as I was borrowing a friends lift to pull the trans, he told me he did not think it was that and there was no way to know without tearing it down. He was right.
I called Tremec and talked to Rob Sheppard, he sent me a form to fill out and fax back to him, I am waiting to see what will happen, I am going to call Mike today and see if he can get the parts ordered. There are pictures in my gallery under transmisson album.
David
Last edited by davecobra; 03-30-2012 at 12:45 PM.. Reason: add info pictures in my gallery
Old 03-30-2012, 12:55 PM
dallas_'s Avatar
I'd say that falls into the category of "not good".
Hope Tremec will help out.
Not much fun pulling the transmission out is it?
Old 03-30-2012, 01:25 PM
Default Great news
Just got done talking to Rob at Tremec and he is sending me the parts for free!!!!!!!!
That is customer service, they stood behind the product that is past there warranty period, and did it within 24hours, what can you say except, THANK YOU TREMEC.
David
Old 03-30-2012, 01:29 PM
No Dallas it was not fun pulling it out, real pain in the butt.
I will be glad when it is back together and running.
David
Old 03-30-2012, 02:42 PM
dallas_'s Avatar
David
wow, that's good news. Please post some photos of the shift rail installation procedure if you don't mind.
Old 03-30-2012, 03:38 PM
Tremec is sending you the parts, including the case?
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
Old 03-30-2012, 06:45 PM
That is correct, new center case and reverse idler gear, shift rail and shift pins, I think they are great, and my hat is off to them and Rob for doing above and beyond what I expected.
David
