SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 01-23-2013, 12:30 PM
GBowman's Avatar
Cobra Make, Engine: BDR #1230/B2 445CI SBF
Default TKO 600 sloppy in 4th
Shifter feels "sloppy" in 4th gear position, it doesn't pop out of gear or anything of that nature it just doesn't feel tight as it does in all other gears. Is there an adjustment? Any thoughts?
Thx
Gary Bowman
Voorhees NJ/Key Largo Fla/Ventnor NJ
Old 01-24-2013, 05:09 AM
Does it have an aftermarket shifter?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 01-24-2013, 09:11 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I did a dry-up this last summer on mine and found 4Th gear had play as the fork oscillated in the slider. The plastic "feet" had worn away allowing metal to metal contact.
If you decide to get this looked at, get the brass sliders they have on the market BEFORE you have the work done. Also, if it is worn, have it welded and ground to make up the worn area. The weld will be cheaper then a new fork - if you can get one.
After the work, use super shift or other slimmy lub over the ATF.
Just my opinion. Hope this helps!
Tru
Old 01-24-2013, 11:29 AM
CHANMADD's Avatar
Also 4th is a direct drive gear.......no layshaft to tighten things up.......
