Like Tree1Likes
  • 1 Post By Rick Parker
Old 11-23-2013, 06:40 AM
crenbbf's Avatar
Default Husrt Comp/Plus shifter ID?
Hi All
Could anyone help with the ID of this shifter.
It was purchased under the assumption it was for a 'stang.
It is to be bolted to a Toploader
http://i1276.photobucket.com/albums/...psa51affa9.jpg
cheers
Old 11-23-2013, 03:03 PM
Rick Parker's Avatar
The shifter mechanism is the same regarless of application, the mounting plate allowed for the location of the shift lever itself. Usually the lever came directly out of the mechanism and if required had a bend in it to move it to the left closer to the driver. The shift rods can be replicated or purchased. Here is an example of an OEM Ford shift mechanism on a T-10.
[IMG][/IMG]
crenbbf likes this.
Old 11-25-2013, 11:48 AM
crenbbf's Avatar
[IMG][/IMG]
Thanks Rick
Must have been a tricky one though only one response
cheers
Old 11-25-2013, 02:18 PM
Cobra Make, Engine: Scratch-built 427 MR
There is a 4 digit # on the mechanism. (Facing to the bottom in your picture). This will help identify it's original application. Should be something like 8327. It will be just above the slot for the bottom shield. Bill.
Old 11-25-2013, 11:38 PM
crenbbf's Avatar
Thanks Bill
Now ID'd and thankfully the right one
cheers
