SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 11-29-2013, 05:45 AM
Cobra Make, Engine: Unique 427 S/C, FE 440, top-loader, 3.31
Default Toploader + Gear Vendors overdrive?
Has anyone done this? Does the Gear Vendors replace the tailshafthousing? Does it increase the overall length of the trans? Can it be installed in a short driveshaft Cobra?
Old 11-29-2013, 05:52 AM
Gear Vendors under/overdrive auxiliary transmissions, Ford 2-Wheel Drive 4, 5 and 6 Speed Manual Transmissions.
Old 11-29-2013, 08:55 AM
CHANMADD's Avatar
Mine is a 4 speed jaguar Moss box with Laycock overdrive unit.......it fits fine ....the driveshqft is about 12 inches.......2000rpm at about.80............2.88 rear and 26 inch dia tires::.....I believe Laycock sold to these guys
Old 11-29-2013, 10:45 AM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
I dont think it would fit. If it might fit, how long would your driveshaft be and how short is too short? Do you have an IRS?
" It ain't no big deal"
Old 11-29-2013, 11:41 AM
Yes I have IRS. Drive shaft around 12 -14 inches. Can not tell from website how much length is added to trans.
Old 11-29-2013, 12:42 PM
Why pay that much for an overdrive unit when you can buy a new TKO for. $2300?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 11-29-2013, 04:42 PM
CHANMADD's Avatar
I agree ...just get a five speed........
Old 11-30-2013, 04:07 AM
Default adds 7" to length of trans
760010M-27 : Ford Range Torque Spliter Overdrive 27% with a 5.125 retainer index | Advance Adapters
Old 01-14-2014, 09:12 PM
Cobra Make, Engine: CSX4000, 427
If you are running a close ratio toploader, you can switch to a wide ratio, and change your rear gears to 2.88's, and you'll have the same overall first gear ratio, now with an "overdrive" like top gear.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Old 01-14-2014, 09:28 PM
Karl Bebout's Avatar
The torque splitter sounds fine, for lower power cars <400 '#s of torque.
Karlos
Rate This Thread:
