Old 10-21-2014, 12:17 PM
crenbbf's Avatar
Default Bolting up a Quicktime to a Toploader
Hi All
I could do with a bit of advice regarding which type of bolts to use.
My Toploader did not have any bolts attached and there are none with the bell.
The bell does have the bell to engine bolts.
The bell is a 6057 so not SFI but looking at the kits the only visible difference is the block plate to bell housing bolts is this the case?
Which bolts do you recommend for both the bell to block plate and also bell to trans ?
cheers Kiel
Crendon 427s/c No68
434FE
Old 10-27-2014, 03:58 PM
Cobra Make, Engine: Classic Roadsters II, Ford
Default quick time to toploader
I would suggest only grade 8 bolts and nuts for bell to block plate and grade 8 bolts between bell and toploader . My quicktime was sfi rated so came with all hardware which was all grade 8 .
Old 10-28-2014, 12:26 AM
crenbbf's Avatar
Ok grade 8 it is
thanks for the reply
Kiel
Crendon 427s/c No68
434FE
Old 10-28-2014, 05:13 AM
mickmate's Avatar
They come with socket heads as some of the bolt pads are a tad small or just a trick to get a spanner on.
mickmate
http://www.actoncustom.com/
