Old 12-21-2014, 01:38 PM
BADSN8K's Avatar
Cobra Make, Engine: BD 1445 Coyote TKO 600 3.91
Default Replacing a 700r4 with BIGGER trans and LS motor
Hello
First off HAPPY HOLIDAYS!!!!
I would like some help from you all!
I recently bought a Everette Morrison Cobra.
Powered with a SBC
Transmission 700r4
All riding on a Corvette Suspension
I am looking to install a LS2 to a LS 4 motor.
I am looking at transmissions
4L60-e would be a nice match..
My questions is would a 6L80 work?
Has anyone assembled this combination?
Appreciate all your knowledge and if you have any docs or images that would be awesome!
Thanks All!!!
Cheers from Texas!!!
Coastal Cobra
Old 12-22-2014, 09:13 AM
Thor maine's Avatar
The 700R4 is a great trans. It does not need any computer and the convertor lock up can be controlled by a simple speed switch. They also can be build to be happy behind 750 H.P. plus a low first gear and a 30% overdrive and it hard to think why you would want to swap it?
Old 12-22-2014, 08:10 PM
Jerry Clayton's Avatar
the 4l60e would be a good mate to the LS engine and compatible with the engine computer for control----
Old 12-26-2014, 06:24 AM
Cobra Make, Engine: built the molds and body composite construction
I would check and make sure your trans will bolt to the LS-series, seem to remember there was a change in the pattern with the LS. Also would suggest to get rid of the transverse springs, if you are running them and go to the coilover conversion, it's a bolt in.
Bill K
