Old 09-06-2015, 05:25 AM
Default Mc leod
Is there someone here that has a mc leod gearbox?
If someone has one,are you satisfied with it.
I'm planning on getting a new engine and gearbox installed and want to know if the gearbox is any good.
The tuner that is going to build the engine recommended it.
Greetings
Old 09-06-2015, 06:46 AM
joyridin''s Avatar
Here is my suggestion and it is pretty generic. If McLeod actually builds the gearbox themselves, it is probably pretty good. If they outsource it, I would not touch it.
I bought some items from McLeod a while back and to this day, they still haven't gotten them correct. All I get from them is "McLeod doesn't actually make that product. It was made on the outside". Who cares? It has their name on it and they sell it. Why do I care who made it for them? That is their excuse why the products are bad and why they can't seem to fix the issues.
Old 10-29-2015, 12:34 PM
Should I go the tremec route then?
400 hp/650 nm torque?
With a 3.54 rear end
And 17" tires
Old 10-29-2015, 12:42 PM
Yes, buy it from Liberty or Bret they will modify it to shift better.
Bill
Old 11-03-2015, 12:11 AM
As I am looking for a tremec transmission I came along a"close ratio" trans.
It's from ford racing,but it's still a tremec.
Is this usable on the street?
Can someone please explane the difference.
Thank you
Old 11-03-2015, 01:07 AM
xb-60's Avatar
Here are the 'standard' options for ratios for the TKO 600 (and 500)....
....is what you saw here?
Glen
Old 11-03-2015, 01:48 PM
Nope, this is it.it said "close ratio"
Are all tremec gearboxes "close ratio"??????
Manufacturer's Part Number: M-7003-R58H
Part Type:Manual Transmissions
Product Line:Ford Racing Cobra R Tremec 5-Speed HD Transmissions
Summit Racing Part Number:FMS-M-7003-R58H
UPC: 756122076187
Number of Gears: Five
Input Shaft Diameter: 1.125 in.
Input Spline Quantity: 26
Output Shaft Spline Quantity: 31
Output Shaft Spline Diameter (in): 1.500 in.
Tailshaft Length (in): 14.500 in.
Bellhousing Included: No
Yoke Style: Slip-on
Yoke Included: No
Shifter Included: Yes
Shifter Style Required: Stock
First Gear Ratio: 2.92:1
Second Gear Ratio: 1.90:1
Third Gear Ratio: 1.34:1
Fourth Gear Ratio: 1.00:1
Fifth Gear Ratio: 0.68:1
Case Material: Aluminum
Quantity: Sold individually.
Notes: 600 ft./lbs. torque capacity.
In-Store Pickup:Choose In-store pick-up (OH, GA, NV) on our web site.
CalculatorGear Ratio Calculator
ToolTransmission Lookup
Old 11-03-2015, 03:18 PM
eschaider's Avatar
I was unaware of McLeod offering transmissions. Do you have a link to the transmission offerings?
Thx,
Ed
Old 11-03-2015, 10:49 PM
From summit,
Email
Overview
Applications
Required Parts
Suggested Parts
Show All
Brand:McLeod Racing
Manufacturer's Part Number: 512957
Product Line:McLeod Musclecar 5 Manual Transmissions
Summit Racing Part Number:MCL-512957
Output Shaft Spline Quantity: 32
Yoke Style: Slip-on
Yoke Included: No
First Gear Ratio: 2.95:1
Second Gear Ratio: 1.99:1
Fifth Gear Ratio: 0.63:1
Case Material: Cast aluminum
The revolutionary and innovative design of McLeod Musclecar 5 manual transmissions gives musclecar owners the ability to use an overdrive tranny without expensive or annoying modifications. They feature an exclusive case design that allows for fitment into tight tunnels. Gone are the days of cutting your floorboards to be able to get the benefits of improved fuel economy and the lower rpm that an overdrive transmission provides. With 8620 forged steel gears and a 32-spline output shaft, the McLeod Musclecar 5 manual transmissions can handle up to 500 ft.-lbs. of torque. The gears are fully synchronized for smooth shifting and quiet operation, while the internal rail shifter aides in quick and smooth shifts--and the front cover is designed to bolt right up to your factory bellhousing.
Warranty
Some parts are not legal for sale or use in California on any pollution-controlled motor vehicles
Back to Results
