SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 05-05-2016, 10:28 AM
fastd's Avatar
Cobra Make, Engine: ERA FIA, 351W
Default Lithium Grease
I have my tremec TKO out to replace and fit a new starter...
Not changing anything internal, same clutch, disc., etc.
Do you guys put a dab of lithium grease on the transmission input shaft? I've read a bunch of different opinions...
Old 05-05-2016, 02:01 PM
Shootnride's Avatar
Cobra Make, Engine: Superformance, 427SO
I have used Honda Moly 60 Paste on splined shafts for years with very good success. I have heard that Honda no longer imports this product but the Loctite 8012 product should work just as well. High molybdenum disulfide content pastes in general work well on sliding splined connections.
http://www.akd-tools.gr/xmsAssets/Fi...DS/8012-EN.pdf
Ted
I should have also said, just brush a thin coat on the splines. You don't want excess that will sling out onto the clutch disc.
Old 05-06-2016, 12:16 PM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
You might also try the liquid graphite spray you use to lubricate locks. When the carrier evaporates it leaves behind a thin film of graphite that won't hurt your clutch.
Bill
Rate This Thread:
