SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-11-2016, 05:16 PM
BAsque1's Avatar
Default Doug Nash 5 speed transmission shifter
My car es equipped with a Doug Nash 5 speed transmission, the shifter is the short type and at times it is very hard to shift. My wife would like to drive the car but shifting is very hard for her. I am considering a longer shifter by Hurst but I cannot determine which model to buy that would fit. Any thoughts from anyone please would be appreciated.
I am watching this on e-bay
Hurst Richmond Doug Nash 5 Speed Shifter Kit 4070015 w Install Kit 457 Trans | eBay
Thanks
Lou
Basque1
Old 06-11-2016, 06:02 PM
Neutral
The lever arm bolt dia and on-center are interchangeable between the "Long" and "Hurst" Shifter brands.
Richmond bought the Doug Nash trannies a few years ago. They recommend the Long Shifters as does G-Force (tweaked internals).
I saw a note on Hurst website on the 4070015 kit. Warning it won't fit if you have 4 shifter rods.
Hurst 4 Speed Race / Richmond 5 Speed Shifters - Hurst Shifters Online
Replacement arms of various shapes start on page 58.
http://www.hurst-shifters.com/wp-con...al_website.pdf
The Long (3 rod) kit is pretty much the same price as the Hurst.
https://www.summitracing.com/parts/lon-hn1000/overview/
https://www.gforcetransmissions.com/...peed_Trans.pdf
Old 06-12-2016, 04:05 AM
BAsque1's Avatar
Thanks for the info, one more question if I go under my car where exactly would I look for an transmission code or id # that would identify exactly which Doug Nash I have?
tks
Lou
Basque1
Old 06-12-2016, 07:13 AM
Tommy's Avatar
This is just a guess. I found this picture that shows a number 71-xxxxx on the passenger side of the case. That may be what you're looking for.
Tommy
Previously owned EM Cobra
Old 06-12-2016, 07:34 AM
Tommy is correct.
http://www.richmondgear.com/pdf/Rich...g_Section2.pdf
Has a PN breakdown , ratios. splines etc...
Old 06-14-2016, 11:50 AM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
I have a Richmond 5 speed and it should not be difficult to shift (which is what the Doug Nash transmission later became). Before you spend the money switching from a short shifter to a long shifter, make sure your existing shifter is properly adjusted. The Richmond uses an external shifter and linkage. There are several bolts through the center of shifter assembly. If they are too tight, the shifter becomes very difficult to shift. I don't recall whether you'll need to loosen only the center bolt or the two bolts to either side.
Old 06-17-2016, 04:06 AM
BAsque1's Avatar
CJ428CJ:
My issue is the length of the lever which is too short and the leverage is too there when I shift, so I am really looking for a little longer lever.
tks
Lou
Basque1
Old 08-25-2019, 08:52 PM
cycleguy55's Avatar
3 years later, so hopefully you've got this solved by now.
If not, it's worth noting Hurst shift levers will bolt on as replacements for the Long lever, though you may need to bend it or space it to move it closer to the centre of the car.
Brian
