February 2026
Like Tree14Likes
Old 05-30-2017, 12:41 PM
cycleguy55's Avatar
I'm hoping,.....in two years, after paying off some medical bills, that I can either build another engine (after eight years of my Cobra sitting in the garage with no motor) or build one.
I've always felt that no engine will be in my Cobra other than an FE. I'm doing a lot of research, but what I'm finding is that even a 428FE is getting harder to find. The 427 aluminum side oiler done the way I want, is 17-20k to buy and apx 15k for me to build.
So, I'm checking into a 358 series, 460/514, as it's lower in cost and a HUGE cost and power difference,.....vs a FE, original or new. For apx 14k, I can have a 514 with 700 HP/TQ.
To have a 700 HP FE, like 28k (+)
Anyway, if I go with the 514 I will need more than the 3550, so that'll mean a stouter tranny.
My Cobra is a Lonestar which is a 94" wheelbase and set up for the Tremec 3550 TKO and 428FE.
The extra 6th gear would be very nice on the highway and interstate.
Is the other Tremec's longer ?
Shifter locations different ?
Tranny crossmember different location ?
I'm a retired dirt sprint car racer, so I need power, 600-700 HP/TQ. My driving style is mixed fun.
What's your thoughts on a tranny ?
The T-56 Magnum is roughly 4" longer than the TKO, though the input shaft is about 1.5" shorter so you gain some of that back. The tranny has multiple shifter options / locations. http://www.tremec.com/anexos/File/TR...erformance.pdf
Quicktime has a couple of bellhousing options to mate the T-56 Magnum to a 385. McLeod apparently also has an option - article here on a T-56 into a '71 Mustang: Mustang C6 to T56 Transmission Swap - FordMuscle
Could be a fun ride!
Enjoy.
Brian
Old 05-30-2017, 12:45 PM
cycleguy55's Avatar
The spread between the two company's is quite a difference.
With the power of the 514, the stock 1st gear of my 3550 would be usless off the line. It already was with my 550 HP 428FE, so depending on a few situations, I'd start off the line in 2nd gear. If I can get the first 4 gears as a close ratio for racing, the 5th & 6th gear can be for overdrive.
Which 460 etc do you have ?
What's the HP/TQ numbers ?
$3,500 bucks for your Richmond ?
1st gear is a parade gear, and 2nd gear starts are easy with a big block.
Mild build 460 - 400 HP / 500 torque.
$3,500 would be a current ballpark price - the transmission was in the car when I bought it in 2014, and the car was built in 1991. Roughly 25,000 miles on it.
Brian
Old 05-30-2017, 02:12 PM
Antny's Avatar
Cobra Make, Engine: SPO 963, 351W
Tremec 5-speed. Because it's smooth as buttah. Oh, and because it was already installed in the car when I bought it. :-)
Old 05-31-2017, 06:04 AM
undy's Avatar
Knowing what engine you're hoping to install Kev I'd steer away from any TR3550s and T5s, just no where near enough of a high torque rating. That leaves the TKO600, T56 Magnum or a B/B top loader. I'd have mentioned the TKO500 but you don't need that deep of a first gear for a big block, especially at the cost of 100 lb ft less torque rating. I've a TKO600 in mine and couldn't be happier with it.
Too many toys?? never!
Old 06-06-2017, 02:55 PM
ALF's Avatar
ALF ALF is offline
Borg Warner T10H case and T10B tail shaft installed on my 289
CompClassics likes this.
Driving with your Cobra is fun,
Racing with your Cobra is amazing,
Driving hill-climbing races with your Cobra is.... HAVEN!!
Old 06-07-2017, 08:03 PM
Cobra Make, Engine: Contemporary Classics, red white stripes
Default TKO, TKO-600RR, Top Loader
I had a 428 with a TKO-3550 and 3.50 locker in a 67 mustang about 15 years ago. It was a bit tight - hard to shift fast. 5th gear was a little too high.
My Cobra came with a top loader and 3.54 Jag rear end. The gear ratios were off. 1st gear wasn't low enough. 4th was too low. Probably has the 2.32 first. I never checked. Highway cruising was painful.
I switched to a TKO600RR. I was worried about the tightness from my earlier TKO, so I got the one modified by Brent Lykins. I am very impressed with how well this transmission shifts. I didn't think it could be smoother than a top loader/Hurst, but it is.
Gear ratios are a little low, but the fix it to go to a 3.31 rear-end. This is with a 428, soon to be a 482. Every change gets closer to nirvana.
Old 06-07-2017, 08:47 PM
We just swapped my TKO600 to a T56. I currently have a 3.27 rear end but plan to do a gear swap. We intend to drive the car to see where the new cam wants to be before committing to a specific gear. I've got a set of 3.90 and 4.30..... we are also gong from a 315/35/17 to a 325/50/15. According to the gearing calculator the 4:30s put my setup similar to if I swapped to a 4:10 with my current tire size. Will be running a 575hp 427 Windsor with drag radials on the rear setup for the street.
Old 06-08-2017, 07:56 AM
Also have a Richmond street 5 speed part # 7041710 was installed in car by shell valley as a assembled kit when purchase by previous owner in 2002 and has yet to have ever been on road so no miles as of yet.
Old 06-08-2017, 07:33 PM
MKS427's Avatar
Cobra Make, Engine: FFR MkIV 427
Default TKO 600 wr od
3.08 gears, so I'm at 1500 rpm at 60 mph with the .64 od. I have the 17" wheels which are a little smaller than the 15s.
Old 06-09-2017, 10:53 AM
moore_rb's Avatar
Cobra Make, Engine: All original, with Chevy engine since 1964
I have a toploader behind my 289... Came with the car.
I thought I would be swapping it out for a WC T-5, but nope... It's not gonna happen.
The toploader reminds me of the Muncie M22 I used to have in my 69 Corvette (both shift like butter, but the toploader is WAY quieter )
with 3.31 gears out back, I can 0-60 in first gear (4.79 is my best so far, according to my Speedhut GPS speedo ), and I can still cruise in 4th at 75mph, turning 2800rpm, and getting 20+ mpg... It's true love.
Pete Munroe and xb-60 like this.
- Robert
Old 06-09-2017, 11:40 AM
cycleguy55's Avatar
I don't know, it sounds like it may be more lust than love...
moore_rb likes this.
Brian
Old 06-09-2017, 01:12 PM
RACERAL's Avatar
Cobra Make, Engine: Factory 5 mk4 445 FE
I have a tko600, 3:55 ass end FE 445. About 2200 rpm in 5th at 60 I think. Its like an automatic... I can go down to about 1200 rpm coming up to a stop light and just roll on
Al Adkins
Stoneville,NC
My ex car. Sad to see it go.
http://www.ffcars.com/POM/nov2003pom.JPG
