SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Like Tree1Likes
  • 1 Post By joyridin'
Old 12-27-2017, 05:52 AM
Default Tranny Richmond to TKO 600
I'm Looking to switch from my Richmond street 5 speed (1:1 5 gear) to the TKO 600 (.82 OD) so far I have found that Southern Automotive has the best price on the conversion kit over MDL and American. Has anyone have any experience with the kit for Southern, I have read mixed reviews on their engine quality and wonder if they have issues with their transmissions.
Old 12-27-2017, 06:08 AM
joyridin''s Avatar
I do not know that much about Richmond transmissions, but I always thought the nice thing about them was you could change the gearing in them reasonably easy. Wouldn't it be more cost effective to change 5th gear to an overdrive ratio instead of changing out the whole transmission? Considering all the issues people complain about with the TKO, that seems like quite a step down in quality.
eschaider likes this.
Old 12-27-2017, 11:38 AM
Fifth gear is straight through. You can't change that ratio because there are no gears involved in the in/out path.
Old 12-27-2017, 02:22 PM
Cobra Make, Engine: CSX4000, 427
i believe the richmond 5spd, is the old doug nash 5 spd, a true close ratio tranny, that was designed to use a street cruising rear gear ratio ( about 3.23 or so), but now with the super low 1st gear, it was like switching the rears to 4.56's with the original 4spd. And yes, 5th gear is 1:1 like was said above.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Old 12-27-2017, 03:06 PM
To the OP: what rear end gear ratio do you currently have installed and what don't you like about your current Richmond setup?
