Old 01-18-2026, 08:36 AM
Default Bellhousing alignment
I'm installing a FE 427 in my cobra with a Richmond 4+1 5speed and a Lakewood bellhousing (from my 428) has anyone perform an alignment? if so how far off from the centerline can I expect?
Old 01-19-2026, 03:40 AM
Senile Club Cobra Member
Lakewood's are notoriously off center, expect a large rectification to be required. Google it, there are several methods of correction.
rick@autoventureusa.net
Old 01-20-2026, 06:03 AM
undy's Avatar
The industry standard for manual transmissions like the Richmond 5-speed is a maximum of .005" (5 thousandths) total runout. They can be out as much as 0.050".
Too many toys?? never!
Old 01-20-2026, 06:05 AM
undy's Avatar
SOS with this POS website!
Old 01-20-2026, 11:26 AM
Here's an interesting thread. Posts 10 and 16 in particular. More about alignment than the thread title would suggest.
https://www.fordfe.com/viewtopic.php?p=1082998#p1082998
Old 01-20-2026, 02:51 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
My Quicktime bell was out. I don't remember by how much. I used the Lakewood weld on washers to get an acceptable total indicated runout.
I view this as a permanent fix. The offset dowels might need fused with each time the bell is removed.
Old 01-30-2026, 12:39 PM
Cobra Make, Engine: Classic Roadsters, 347 stroker
Just plan on checking the runout with a dial indicator. Then go from there. There are offset dowel pins available from many manufacturers. I highly suggest, regardless of price two options. Either the Lakewood offset dowels or RobbMC offset dowels. The Lakewood options fit the block very well and are accurate. I drilled a tapped a small set screw in the block to keep the pins in place so whenever I have to pull the bellhousing, they stay in place. The RobMC dowels have a center set screw inside the dowel that are nice, I was going to go that route as well.
Old 02-05-2026, 08:34 AM
eschaider's Avatar
Here is chapter and verse on how to do this job and what you need to shoot for, click here =>A PSA about cast iron flywheels..... Do not be put off by the cast-iron flywheel nomenclature. The write-up on bell housing alignment is excellent, if I do say so
Old 02-05-2026, 10:29 PM
Exclamation
Is this on the other site, Ed? Perhaps it would be good to port it over there for easy access during those dark times in this area of the web... if you know what I mean!
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
