Old 03-20-2003, 10:02 AM
ian ian is offline
Default Ford Windsor bellhousing question
Can anybody tell me please if the bellhousing from a Ford 302w (manual gearbox type) will fit a 351w engine. I have been offered an aluminium one. Also, are there any implications on clutch/clutch mechanism that I should be aware of? I thought all Windsor bellhousings were iron! Thanks. Ian.
Old 03-20-2003, 10:06 AM
Mr.Fixit's Avatar
Get an SFI approved scattershield.
Old 03-20-2003, 10:13 AM
Leo Leo is offline
Ian,
The bell housing bolt pattern is the same for a 302 or 351W block. Many 5.0 Mustangs (and I'm sure others) had aluminum bellhousings. As most vehicles (especially kits) don't provide much protection a scattershield is usually a good idea for performance applications as even the iron (?) bellhousings are cast.
Old 03-20-2003, 10:34 AM
Cobra Make, Engine: Levy Racing built FFR w/351W
Option #2, go with the bell housing and use a kevlar blanket for safety.
Old 03-20-2003, 07:17 PM
The bolt pattern is the same but there were two different flywheel sizes, 157 tooth and 164 tooth. Get the casting numbers and go to http://www.davidkeetoploaders.com/be...ingidchart.htm
Old 03-21-2003, 10:09 AM
ian ian is offline
Thanks everyone for your replies. I'm trying to find out the casting number. Ian.
Old 03-21-2003, 10:33 AM
Cobra Make, Engine: B&B 408W, TKO 600, 9" 4-link Truetrac, 13" X 1 3/8" curved vane frt disks
How many of you are using a Kevlar Blanket? Where did you buy it? How much did it cost?
Old 03-21-2003, 05:31 PM
Call Levy Racing, 480-446-8442
