Old 06-08-2003, 09:53 AM
Cobra Make, Engine: B+B 351w #112
Default Changing t-5 question
Is it possible to change the transmission without taking the bellhousing off the rear of the engine? I took the old one out this way. Jim
Old 06-08-2003, 10:01 AM
Ron61's Avatar
Post
Jim if the new one has the same shaft and spine you should be able to. I have taken mine out and put it back with no problems.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 06-08-2003, 02:35 PM
Hello Jim,
You should be able to remove the 4 trans bolts, and the trans should slide right out. No need to remove bellhousing unless clutch/flywheel needs work.
Old 06-27-2003, 07:38 PM
so how do you take the tranny out and still support the engine? I'm going to have to move the car while the tranny is out so what is the best way to go aboot it?
Moderation is a fatal thing, nothing succeeds like excess!!!
Old 07-11-2003, 08:12 PM
Motor mounts should hold it fine. Trany back in and back on the road. Jim
