SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 07-01-2003, 11:07 AM
Cobra Make, Engine: SPF/white/blue/smallblock427/webers
Default pro-50 shifter Dust Boot
I am looking for a dust boot (shift turret) for my newly installed Pro-50 shifter on my TKO II trans that resides in a Superformance Cobra. Does any body have a Ford part number for this dust boot? Does anyone know what year Ford Mustang Cobras used the tremec transmissions?
Old 07-01-2003, 11:31 AM
Chaplin's Avatar
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
I'd be interested to see if anyone has an answer to this. I just tried to install my shifter boot (std. cobra boot and trim ring) over my Pro 5.0 shifter and the boot and trim ring will not fit over the two bolts that are designed to limit the throw of the shifter (the bolts that are at 12 o'clock and 6 o'clock on the shifter). Has anyone else had this problem? Is there a bigger boot and trim ring that you can use or should I just cut down those two bolts somewhat?
Replica is not a dirty word.
Old 07-01-2003, 11:46 AM
mikiec's Avatar
On my FFR I had to notch the tunnel slightly to allow for the PRO 5.0 shifter stop bolts to fit. The standard boot and trim ring fit nicely.
Mike
Old 07-01-2003, 04:18 PM
Cobra Make, Engine: ERA 575 with Shelby Aluminum 427 Stroked to 468
if I understand the problem correctly, you're having trouble stretching the boot over the stop bolts. If it were easy it wouldn't be any fun! The act of getting the boot over the bolt is only an issue because, unless you've removed the tunnel, you've got no easy way to get leverage. I think on mine, I took a big screwdriver, wrapped several layers of masking tape over the head of the screw driver, and than pryed the boot over the bolts from the inside of the boot, in other words, depressed the screwdriver into the outer perimeter (from the top) and then pulled it over the bolts.
Old 07-01-2003, 08:37 PM
Cobra Make, Engine: SPF with 514 and tko
Default dust boot
If you need a dust boot for the Pro5.0 that keeps dirt etc. out of the shifter mechanism, but fits under your stock shifter boot try performanceunlimited.com
