SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-13-2003, 08:43 PM
timsullivan's Avatar
Cobra Make, Engine: Superformance SPO2820 408W; former ERA CCX 3-3408 owner
Default Tremec 3550 TKO II -Clutch Arm Pivot?
I've just bought a Tremec 3550 TKO II that I'm planning on bolting up to my 428 with a Lakewood FE scattershield and Mcleod adaptor. The scattershield, which I brought used came with a small "L" shaped bracket about two plus inches wide that I assume the clutch fork pivots on? Am I missing something here? I read that the application I'm building this for (ERA Cobra) requires a Clutch Arm Pivot (FE Ford C8AZ-7522B) which the local Ford dealer tells me has long been out of production. Could the existing bracket that I mentioned above be this Clutch Arm Pivot? If not, any thoughts on an alternative pivot that I could source somewhere? (I'm not interested in doing any kind of hydraulic clutch arm set up.) Please let me know your thoughts.
Old 07-14-2003, 06:06 AM
Clois Harlan's Avatar
Tim,
I took mine off and I think it was about 2" but I don't think it was shaped like an "L" perhaps it looked more like a "W". I didn't have enough room for a clutch arm so I went with a hydraulic throw out bearing. Good luck!
Clois
PS-If I remember correctly the clutch arm requires a lever to push it back and is attached to the drivers side rear of the block. I still have my clutch lever but I haven't found my pivot braclet that attaches with two flat head 1/4" screws inside your Lakewood bellhousing. If I find it tonight you are welcome to both parts.
"Let's roll"
"Be part of Something Good
Old 10-29-2003, 05:55 PM
surfer44's Avatar
Cobra Make, Engine: Hi-Tech Serial 0122 66 428, Tremec 3550. AMP 9" Ford IRS
Send a message via AIM to surfer44
Tim,
Yes, my pivot was "L" shaped and about two inches long and it worked fine for installation on a Lakewood scattershield.
Thanks,
Neil Brady
"Life is not a journey to the grave with the intention of arriving safely
in a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out and loudly proclaiming:
"WOW, what a ride!!!"
Old 10-30-2003, 06:43 AM
Tim...this is the C8AZ you're looking for....
George
Clutch Arm Bracket for Lakewood
Another View of Clutch Arm Bracket
Old 11-02-2003, 08:59 AM
Many thanks guys. As usual your saving my bacon here...
Old 12-21-2003, 04:38 PM
Hi Tim,
I'm making a conversion to an external slave asm for all of the Lakewood & McLeod bellhousings. I make the slave bracket, pivot, billet fork, adjusting rod complete with the bellhousing. The bellhousing is complete and ready to install. For mechanical linkage with the 1 1/16th input I have a billet fork & pivot to replace the parts no longer available from Ford. Call me with any questions.
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
