Old 11-10-2003, 04:36 PM
Default Correct throwout fork?
I have aC8AZ-B fitting to hold the fork and a McLeod p/n 16100 throwout bearing, but the C80Z-D throwout fork does not fit, it is too large a diameter for the throwout bearing and does not fit into the fitting attaching it to the bellhousing. Does anyone know the correct fork and where I can find it?
Tom
tj61@juno.com
Old 11-10-2003, 04:45 PM
surfer44's Avatar
Cobra Make, Engine: Hi-Tech Serial 0122 66 428, Tremec 3550. AMP 9" Ford IRS
Send a message via AIM to surfer44
What is the diameter center to center of your throwout fork. I have two I bought off EBAY.
Neil Brady
"Life is not a journey to the grave with the intention of arriving safely
in a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out and loudly proclaiming:
"WOW, what a ride!!!"
Old 11-10-2003, 05:31 PM
Default Fork Size
The C80Z-D fork is about 2" diameter and 10.5" center to center. The throwout bearing (McLeod) is about 1" 5/8" OD (no calipers, just eyeball). Either one of these ring a bell?
Tom
Old 11-11-2003, 05:09 AM
surfer44's Avatar
Also look in my gallery I added more angles. The top one uses a clip and the bootm one uses a pin for mounting.
Neil Brady
Old 11-11-2003, 09:42 AM
Default Almost
The top one with the clip is the one I need, only for a smaller diameter fork. Neither one in the photos look correct.
I appreciate the help and photos, seems nothing will be easy with this build....
I wonder if I can use a late model mustang fork? I am making another trip to the parts store this afternoon.
Old 11-11-2003, 10:07 AM
surfer44's Avatar
AMEN!
All I can tell you is the throwout bearing that would fit mine was 1970 Ford truck. GOOD LUCK!
Neil Brady
Old 11-11-2003, 10:21 AM
Clois Harlan's Avatar
Tom,
I appologize if I overlooked your set up but I didn't see it so what engine and transmission are you running. I have both small block and big block forks at home that I didn't use.
Clois
"Let's roll"
"Be part of Something Good
Old 11-11-2003, 05:15 PM
Sorry, I have a 390 with a Lakewood scattershield and Tremec TKO. I appreciate your persistance!
I got the flywheel back and it resurfaced great, A minor victory at last!
