SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 02-21-2004, 05:12 PM
Clois Harlan's Avatar
Default Need Help W/ Trans Spacer?????
Nothing is ever easy that is worth while...Right?
I Rec'd my New Gen II McLeod Hyd T/O brg yesterday and while setting all my gaps I find my tolerances have changed.
So here is what I have done:
Replaced my standard steel flywheel w/ new McLeod Aluminium flywheel w/ steel insert.
Replaced clutch w/ new Performance Hays Clutch
Replaced pressure plate w/ new McLeod Performance press plate
Here are my new dimensions:
Clutch fingers to the outside face of my bellhousing = 2.900
Face of T/O brg to face of trans + 3.020 (adj all the way in)
Problem is I need a gap of .100 between clutch fingers and T/O brg which means my distance between my brg and my trans cannot be anymore than 2.800. This means I need to either use a spacer between my bellhousing and engine or my bellhousing and my transmission of at least 0.220. As you know this is almost a 1/4 of an inch and this seems like an extremely large gap to make up. Has anyone delt with this problem before?
Comments or suggestions please!
Clois
"Let's roll"
"Be part of Something Good
