| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
06-03-2004, 09:46 AM
CO
Cobra Make, Engine: None Yet
Pictures of your Automatic Shifters
I would like to see how some of your shifters turned out.
Advertising
06-03-2004, 09:58 AM
BC
Cobra Make, Engine: F5 Roadster
console / shifter
Hi,
I have a B & M quicksilver ratchet shifter for my C-6.
Works great,bangs 1 gear at a time.
Look in my picture gallery.
Perry.
06-03-2004, 10:08 AM
NJ
Cobra Make, Engine: West Coast Cobra, 427SO 2x4's, 630HP/600TQ
Neat set-up.....
HIghPlains:
That Roll-bar/Head-rest set up is the cats ass. Was that fabricated or is it an off-the-shelf unit? I like it a lot. Safety that adds a nice touch to the car.
Bern
"Shut up and take the pain".
06-03-2004, 10:32 AM
BC
Bern,
I had a race shop fab up the dual rollbars and mig weld the 6 point together with extra frame braces to pass NHRA tech. Then I cut 1/8" aluminum plate to fit the rollbar and drilled and tapped it with allen screws to hold on the black powdercoated headrest supports. I cut 3/4" plywood to match and had a rod shop pad and upholster the headrests to match the seats. The wife loves the headrests, I used to get S$$t for stepping on the gas[whiplash] now her head is cushioned and I don't think any performance car should be without headrests if your going to drive it hard.Thanks for the kind words.
Perry.
06-03-2004, 10:54 AM
NJ
Good stuff.....
Perry:
Thanks for the time and details. I will look into doing a modified clone of yours. I already have a full two seat roll bar which can be braced off of. You did a nice job on it. Thanks again.
Bern
06-03-2004, 10:55 AM
NV
Cobra Make, Engine: Kirkham#182/Shelby 496c.i.
Here's CSX2589 with the automatic configuration.
(courtesy of csxinfo.net)
"You can NEVER teach a pig to sing! You'd just be wasting your time and annoying the pig!"
06-03-2004, 11:44 AM
FL
Hi wire nut,
Here's mine:
It's a '65 Mustang shifter -I'm told some of the originals had these.
Regards,
Tom
06-04-2004, 03:27 AM
CO
Cobra Make, Engine: Want a Lone Star, have a 429 big block and C-6 auto
Awsome, I like the look of the fittted to the consol style. Perry was your shifter for a mustang or other factory consol or did you remove the box plastic thing that a lot of universal shifters have?
06-04-2004, 06:53 AM
IN
Cobra Make, Engine: Unique Motorcars 427 Cobra. 427 Side Oiler. Dual Quads.
Here's mine
Here's mine
1st car was a Cobra, hopefully my last will be also!
06-04-2004, 04:35 PM
FL
Automatic shifters
Here's mine....
Yeah, I know, that LOOKS like a 289 Cobra 4-speed shifter - well, I guess it SHOULD, because that's what it IS. I grafted a 289 Cobra 4-speed shift lever onto my C-4 shift lever. Even the reverse lock-out works. I put a slight "bend" to the left in it, so when the C4 is in "Park" the shifter appears to be in the position of "Reverse" for a Ford 4-speed.
Here's what it looks like under the tunnel:
I mounted the shifter bracket to the tranny, so it even "shakes" like a stick-shift shifter. The boot comes up high enough that I did not even bother to have the shifter handle re-plated after all the heating, bending, and welding.
regards,
cobrajeff
CobraJeff
ERA P 202
06-04-2004, 05:05 PM
BC
Bracket
JP,
The B&M comes with a 3" tall black plastic mount also for floor mounting, I didn't use it, just made 3" metal extensions to lower the shifter into my consol.
Perry.
06-04-2004, 07:02 PM
Jeff,
That is a FANTASTIC job. Looks terriffic.
Ben
"The single best reason for the invention of gasoline."
06-04-2004, 08:35 PM
IL
Cobra Make, Engine: Bare Aluminum pre-Kirkham CSX4000 427 Stroker by Southern Automotive.
An automatic shifter that works for me
In our CSX, I used a Mustang shifter with the wood T-handle from a '68-'70 Shelby. It has the chrome Shelby Cobra emblem on it. I used the shift indicater bezel from a '67-'68 Mustang so I would have the desired in line, progressive, pattern trimmed in chrome. 12DNRP The earlier '65-'66 bezel has 1D2NRP. I always change the valve body in an early Mustang to the newer style, to facilitate progressive gear, speed shifting too.
ST
I noticed in the picture of CSX2589 that you posted that it has what appears to be a '69-'70 shifter and bezel. But then, I could be wrong.
Fast Farmer
06-05-2004, 10:04 PM
CO
Verry nice!! Jeff you must have put a lot of thought into getting it just right. Were you able to use back up light and neutrial safety connections? Necessity is the mother of invention.
Any more?
06-09-2004, 04:44 AM
I'm using the B&M Hammer, I ended up dropping mine into the tunnel about 3 inches to get the correct ergonomic feel. Pictures are in my gallery.
John
