SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 05-11-2005, 11:04 AM
Cobra Make, Engine: Shell Valley Cobra Kit -428 Fe Built by Clayton Racing Engines
Default Trans T10
I have a borg-warner T-10 model 436B 4sp. It came with my Cobra. Question is how strong is this trans and where was it used?
Old 05-11-2005, 11:20 AM
Rick Parker's Avatar
The T10 was OEM for Ford/GM until the stronger Top Loader was developed by Ford. It was OEM in all the small block Cobras and early Mustangs including the Shelby GT350 which I think used an aluminum cased version. The Iron cased model came in some of the 61 and maybe 62 Galaxies with 390/406
Rick
Old 05-11-2005, 11:21 AM
Cobra Make, Engine: CSX 2189
Relatively strong but NOT for drag racing or hard competition shifts. The Warner was used by Chevrolet, most notably, in the Corvette from '57 (mid year option) through '63 (mid year). It was replaced by the Muncie M20, 21, and 22.
It was also used by Ford with a different gear configuration than Chevrolet (the Chevrolet ratios were better). The 289 Cobras and Mustangs used the T-10 with the 427 cars using the Toploader in '65 (the TL was introduced in the Ford line up in '64 although I know of no original 289 Cobra that ever had one installed from the Factory).
You can still get gearing for the T-10 but most racer use the Super T-10 which is much like a Muncie and those gears are readily available from Borg Warner.
