SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 05-27-2005, 09:49 PM
Cobra Make, Engine: NAF replica, 351W, about 420 HP
Default T5 Transmission gear ratios?
Anybody please tell me the gear ratios in a regular T5 transmission?
Thanks in advance!
Edley, The Cobra Rogue!
"If you think that you can cut it, if you think you got the time, you'll only get just one chance, better get it right first time. 'Cause in this game you're playing, if you lose you got to pay, and if you make just one wrong move, you'll get BLOWN AWAY. Expect no mercy.
Old 05-27-2005, 10:13 PM
Buzz's Avatar
Edley, go here:
http://www.fordmuscle.com/archives/2...p/index2.shtml
Tropical Buzz
Old 05-28-2005, 10:48 AM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
The numbers on my T-5 are: 13-52-066-908?
The only thing that seems to match the chart is the 13-52??
Any suggestions, T. Buzz??
Safe Flyin, errrrr Drivin, Earl
Old 05-28-2005, 11:52 AM
Buzz's Avatar
Earl, 13-52-065 is from a 1984 Mustang/Capri 5.0 V8
and..13-52-067 is from a 1984 SVO w/Hurst 2.3EFI Turbo
066 shows "don't read casting number"
I guess you can safely bet it's from a '84 Ford Mustang of some type or another. You can do some digging at:
http://www.5speeds.com/t5/index.html
Good luck.
Tropical Buzz
Old 05-28-2005, 02:51 PM
Send a message via AIM to Chris Robinson Send a message via Yahoo to Chris Robinson
http://www.ddperformance.com/Trans%20ID%20chart.htm
Old 05-28-2005, 07:42 PM
Ouch Ouch Hot Sand
I can not find the 066 ID anywhere or a reference to it other than the one Buzz indicated??????????????????
Old 05-28-2005, 08:53 PM
Buzz's Avatar
Earl, did you get that number off of the stamped tin tag or did you read it off a casting. If it's a casting, it won't be of any help. Gotta be the number on the tag. I suspect 066 just a casting I.D. number.
Tropical Buzz
Old 05-28-2005, 09:12 PM
Ouch Ouch Hot Sand
Buzz, there is no tin tag. The number I read is cast into the box where the shifter is mounted. I did find the following sequence cast into the main body of the T5; 13-52-065-904. A little different than the others, but again, No tin tag...........Thanks, Earl
