Old 03-25-2006, 04:26 PM
JCoop's Avatar
Default Amsoil 75W90 in Tremec?
Has anyone used the synthetic multiweight on their 3550s? Any ill effects of using this instead of the DexronIII ? It just seems like the ATF is almost too thin in viscosity. I drained the old oil in mine and put 2.5 qts of Amsoil and it's shifting so much better. I just hope I don't do any damage. Easy enough to drain and refill...
Opinions?
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
Old 03-25-2006, 08:27 PM
Cobra Make, Engine: Cardiac, 428 FE
Default Amsoil
I've been running that same Amsoil in my Doug Nash Richmond 5 spd with absolutely no problems. I called Richmond and they recommended Redline but said Amsoil would be just as good. Think that may be because they have some deal with Redline.
I've been using Amsoil in all my vehicles and in everything that holds oil for over 20 years. Started using it when I lived in Anchorage because my Chevy Blazer 350 just barely turned over in the mornings during the winter. Had to be doing damage during warmups. Never looked back. Been using synthetics since then.
Paul
Old 03-25-2006, 08:45 PM
onefastmustang's Avatar
Redline makes some good stuff. I use it in all of my cars. Its a bit spendy though. The only reason I started using it is because they are 5 minutes away from me in Benicia. I have never tried Amsoil. I might have to pick some up for my new car and give it a whirl.
Old 03-26-2006, 05:14 AM
JCoop's Avatar
Thanks for the replies. I actually looked for Redline at 2 speed shops but they only stocked Amsoil. My friend and mechanic said he wouldn't hesitate to use it after seeing and smelling what came out of the Tremec. It was almost like water; I guess it had ATF from the factory.Some guys are anal about using only what the factory recommends for 1 reason or another.
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
Old 03-26-2006, 08:21 AM
75W90 will be too heavy for a tranny designed to run with DexronIII or Mercon ATF. The newer tranny's like T5's, Tremecs, et.al, were designed with different synchro plates that I believe are paper backed and require the ATF to work smoothly and extend their life.
Try a search on Tremec transmissions and you'll find what is recommended and why. There is lots of information on this subject on the web.
Old 03-26-2006, 08:46 AM
I wouldn't use that heavy of an oil. You won't be able to shift the thing in the morning unless the outside temperature is 90 degrees.
I used normal synthetic motor oil in mine. 10w-50 seemed t work great. You can shift it with one finger, and after 50k miles, the trans showed no signs of wear.
Old 03-26-2006, 03:34 PM
Default 3550 shifting
Interesting info guys.
My tremec shifts great cold or on the move, but after it heats up driving around awhile, its hard to shift into gear and really doesnt like going into reverse (even going into 2nd 1st) from a stop. Sound familiar to any of you. Did the synthetic stuff help?
Old 03-26-2006, 04:15 PM
JCoop's Avatar
It does sound like a big jump from ATF. It's shifting great, though. And it was 45 degrees when I went for a test drive.
My tranny never liked to go in reverse. The only way was to go to 1st, then reverse. Even then I'd sometimes get a grrrr and had to double-clutch. Now, it seems to be so much better.
This worries me...>>The newer tranny's like T5's, Tremecs, et.al, were designed with different synchro plates that I believe are paper backed and require the ATF to work smoothly and extend their life. <<
Although I haven't found any explanation for the ATF recommendation in any of the tranny/Tremec sites, perhaps I should revert...
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
Old 03-26-2006, 04:20 PM
John McMahon's Avatar
Cobra Make, Engine: SOLD: 2013 Boss 302 Mustang #2775 (both options). SOLD: 95 Mustang Cobra R #4 of 250 "Rosie's Diner" car. SOLD: CCX2-2505, #5 of 7 289 FIAs ever produced at Contemporary! my first Cobra: Unique 427SC w/ 428CJ moder!
I've always have been told to:
A) Use GM SyncroMesh fluid in a Tremec trans and that is what I did.
B) Use Redline synthetic as recommended by the manufacturer in my Richmond Gear.
REMEMBER....In Case of Spin....Both Feet in!!!!!
Old 03-26-2006, 06:23 PM
Buzzmobile's Avatar
Cobra Make, Engine: SPF 148 with 427 SO
I tried the royal purple ATF and got new leaks..went back to synchromesh as recommended by tremec. no leaks...
Old 03-26-2006, 06:54 PM
Bob In Ct's Avatar
Hey guys, keep in mind that a 30 WT motor oil has about the same viscosity as a 90 WT gear oil (give or take, I don't have a chart in front of me). Motor oil does not use the same scale a gear oil, it uses a lower one.
I've been using Redline MTL in my Tremec for 5 years with no problems. Tremec recommends Syncromesh by GM.
Old 03-27-2006, 08:28 AM
JCoop's Avatar
So that means the 75W90 Amsoil is equivalent to like a 5W40 motor oil...
Which now makes sense. Anyway, I just ordered GM synchromesh but Ill keep the Amsoil in a jug when I drain it. ($30 synthetic flush...geeez)
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
Old 03-29-2006, 04:46 PM
JCoop's Avatar
As a follow up, I changed the Amsoil to GM Synchromesh Fluid as recommended (by Tremec) and I have to say, she shifted much better and smoother on the Amsoil 75W90 synthetic.
Wonder if Three Peaks has more info on the "paper-backed synchro plates" that require ATF to function properly...
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
Old 03-29-2006, 04:48 PM
I have T5 out of 95 Cobra that I need to fill. Does the same hold true for that tranny as far as requirements??
Old 03-30-2006, 04:28 AM
JCoop's Avatar
Here's a lift from the TTC site:
http://www.ttcautomotive.com/English/faq/faq.asp#13
Technical Questions
What type of lube is recommended for my TREMEC transmission?
The following types of lube are recommended:
TR-3550/TKO - GM Synchromesh or Dexron III
TR-3650/T-45/T-5 - Dexron III
T-56 (Ford and GM) - Dexron III
T-56 (Viper only) - Castrol Syntorque
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
Old 09-14-2006, 07:08 PM
Cobra Make, Engine: Hurricane, 351w, TKO 600/.64 5th
Btw, you can purchase the Pennzoil brand syncromesh for 1/2 the price at Autozone. Pennzoil supplies the oil for GM and they sell it under their own name.
Do a google search and there are a few articles on this fact.
Herkypilot
