SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
  #21 (permalink)
Old 04-04-2006, 09:19 AM
Cobra Make, Engine: ERA 427 SO
Burgs, that's a good approach, loosen the clutch cover bolts, so there is no pressure on the disc (and replace three bolts with longer bolts to hold the cover in place)...at that point, if the disc is stuck to the flywheel, you can carefully pry the disc loose and re-install the clutch cover fairly easily.
If it isn't stuck, Bill K is right and out it all comes...bummer. Let us know what you find.
FWIW, when it happened to me, it was a new clutch on a freshly surfaced flywheel, and I HAD to have the inertia of the car loading up the driveline while I floored the gas pedal (clutch pedal depressed) to break it loose...the brakes would not have broken the bond. Car went about 100 feet floored before it broke loose.
Ken
  #22 (permalink)
Old 04-10-2006, 06:09 PM
Burgs's Avatar
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
I was able to loosen the pressure plate a little bit, but the fingers hold things up with the throwout bearing. I must have messed with it enough, because it released pretty easy this time. I pushed it out in the street and started it in second gear. As soon as the car took off, it released, and off we went.
Thanks for all the help!
Rate This Thread:
