Old 10-25-2006, 01:16 PM
Dominik's Avatar
Default 5-speed toploader
good day,
I thought I asked before but can't find it:
is there a 5-speed toploader, that bolts right into the place of the 4-speed?
dominik
Old 10-25-2006, 03:50 PM
No, if there is it's news to me.
" It ain't no big deal"
Old 10-25-2006, 04:09 PM
I think it's called a tremec.
Old 10-25-2006, 06:07 PM
pgermond's Avatar
I think you are right!
Phil
http://www.uniquecobra.com/
Old 10-25-2006, 10:34 PM
Dominik's Avatar
Default tremec
good day,
and will it fit into the original chassis without changing the trans mount and yoke?
dominik
Old 10-26-2006, 04:44 PM
The Tremec will easily fit, but the mounts will be different as well as (i'm pretty sure) the yoke.
Old 10-26-2006, 09:20 PM
Dominik's Avatar
good morning,
I see. The other challenge is the narrow tailpiece of the toploader whichis very close to the handbrake bracket of original cars.
I wonder if the Tremec would clear that bracket.
Does Kirkham or Shelby offer a 5-speed?
I shell ask them.
Dom
Old 10-26-2006, 09:23 PM
good day,
The cross member needs to be notched to make room for the 5th OD gear housing. I'm not sure on the yoke, if it's 28 spline standard, and 31 for the TKO, or the total tranny length, impacting length of driveshaft.
Old 10-27-2006, 07:45 AM
Jimi G's Avatar
I believe as long as you use the short shaft kit you will not have to notch the cross member. It is a 26 spline input shaft and a 31 spline output shaft. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
