SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 01-28-2007, 06:41 PM
BeasleyRB's Avatar
Cobra Make, Engine: B & B , 351W 400+
Default Mechanical Clutch linkage at bellhousing
I have a 351W, McLeod BH, Ram Clutch, Tremec TKO. I want to use a mechanical clutch cable and would like some advice and/or pictures of how you guys set up your clutch linkage at the Bellhousing. My clutch arm needs to go to the rear to release the pressure plate. I suppose I will have to fabricate a bracket but was hoping to get some guidance.
Thanks, Bob
Old 01-28-2007, 06:54 PM
BeasleyRB's Avatar
Default Clutch setup
This is what my engine, BH, trans set up looks like.
Thanks, Bob Beasley
Old 01-28-2007, 09:55 PM
LMH's Avatar
LMH LMH is offline
With using a cable, you're probably going to have to fab up a bracket. Most use a hyd slave, so probably not much manfactured for a cable that pulls from the rear.
Maybe bracket it to the frame of the car. Just a thought.
Old 01-28-2007, 10:16 PM
Rick Parker's Avatar
If you must use a cable (?) have the inner cable go through the lever from the front and achor on a fabricated bracket attached by the 2 bolts that attach the transmission to the bellhousing. Have the outer cable and cable end stop at the lever. When the pedal is depressed the outer cable will slide and "Push" the lever to the rear.
A hydraulic setup is a better way to go when the lever must go to rear for release.
Rick
Old 01-29-2007, 06:19 AM
BeasleyRB's Avatar
Thanks, Maybe I should have thought of this when I bought the clutch. If someone has pictures of or can recommend a "push" hydraulic set up I would appreciate it. I haven't worked on cars in years and cannot believe how far behind the curve I am. Bob
Old 01-29-2007, 06:39 AM
289fia_cobra's Avatar
Will something like this help?
http://www.fortesparts.com/catalogDisplay.cfm?cat=60
Mike Forte is located out in the New England area.
My Build Site
Old 01-29-2007, 08:01 AM
Clois Harlan's Avatar
Bob,
If you decide to go this route with slave cylinder I have a couple brand new Wilwood master cylinder Kits that I will make you a great deal on.
Clois
"Let's roll"
"Be part of Something Good
Old 01-29-2007, 08:05 AM
BeasleyRB's Avatar
Thanks, Clois. It looks like that makes the most sense. I would like to see the Wilwood master cylinder you have so I can be thinking how to make it work with my pedal set up. Bob
