Old 02-04-2007, 07:22 PM
BeasleyRB's Avatar
Cobra Make, Engine: B & B , 351W 400+
Default Clutch Master/Slave bore selection help
Wilwood has a clutch master with 3 available bore diameters (.75, .700, .625) and the "Pull Type" slave is .88 inch. How do you decide which master bore is the best one to use? Smaller the bore, less clutch pedal effort but shorter the stroke on the slave. I don't want to make the mistake of not having enough stroke to release the clutch effectively. Thanks for your help.
Old 02-04-2007, 07:51 PM
jwd's Avatar
jwd jwd is offline
My Wilwood set-up is the 260-3378 1" bore master cyl. and the 260-1333 slave cyl.
