Old 04-07-2007, 04:25 PM
double ugly's Avatar
Default Toploader code
Can anyone tell from this code which toploader we're looking at? Close ratio verses wide.
The number on side is C4AR-7006-A There's a number below it that starts with a W-2C"8?"5 "7?"
Thanks, John
double ugly
Old 04-07-2007, 04:50 PM
Gear ratio is determined by tooth count on second gear.
If it has 28 teeth, it’s a close ratio. If it has 31 teeth, it’s a wide ratio.
Old 04-07-2007, 05:39 PM
tmareina's Avatar
Cobra Make, Engine: Unique #9159 428 FE 614HP by FE Specialties
David Key has all the numbers and ratios along with the origonal type vehicle the transmitions came from on his web site.
Check it out.
Tom
Old 04-07-2007, 06:31 PM
Ibr8k4vetts's Avatar
There should be a metal tag on the side of the tranny with letters and numbers. if not you have to do a tooth count on second gear.
Mike Z
Old 04-07-2007, 07:25 PM
If the tranny has ever been rebuilt, then there is a chance the gears may have been swapped
