Old 04-12-2007, 09:01 AM
elgecko's Avatar
Cobra Make, Engine: Scratch build......a little every day.
Default Quick auto trans question....
Could anyone tell if there is a way to "pressure test" an automatic trans C4 before installation? Transmission shop??? To make sure the fluid pump is working.
I'm not a transmission expert, as you can tell
55 mph is unsafe at any speed. Huh?
Old 04-12-2007, 09:38 AM
Archrms's Avatar
Cobra Make, Engine: Superformance SPF#2572, 427 S/O 2X4
Its been years since I've rebuilt a trans, but we used to test the circuits with compressed air. The compressed air will activate the different clutch packs when applied to the correct line (usually at the valve body to test the entire circuit, or directly to the drums in some cases) so that you can verify that they are working properly. I don't remember if there was a way to test the pump itself. Maybe someone else can help there.
Peace through superior firepower...or is it horsepower? Either way, more is always better!
Old 04-12-2007, 04:17 PM
Tom Wells's Avatar
elgecko,
Interesting. I don't know of a way to test the front pump either, but if you are concerned enough to question whether it is working correctly, you may want to take it to an expert to get it checked.
It's infinitely simpler, quicker and easier to do if you already have it outside the car! Try to find someone locally who can give you a recommendation about who to take it to.
Tom
