05-20-2007, 07:36 AM
az
Best way to clean tranny case?
I bought a TR 3550 with 4000 miles on it and want to clean the case. Any suggestions on the best product(s) to use?
Thanks, John
double ugly
05-20-2007, 08:01 AM
Il
John, I use and highly recommend a product called S100. It is available through most bike (motorcycle) shops and is unparallelled in it's abilities. I have used many products over the last 40 years and I have used this exclusively for about a decade. It is also known as Total Cycle Cleaner in some shops. It has abilities not even listed. I used it to clean an old BMW I was getting ready for a couple's anniversary and when I used it on the chrome it even eliminated the surface corrosion that was developing. I've used it to dissolve the gunk in carb bowls, it is bio-degradable and is safe on the skin. Oh...Did I say that I really like the stuff???
WDZ
05-20-2007, 08:12 AM
Brake cleaner works pretty good.
Jay
05-20-2007, 09:33 AM
az
Thanks, I'll get some.
double ugly
05-20-2007, 10:50 AM
One of the best things for simple de-greasing is WD40.
05-20-2007, 12:55 PM
az
I am hoping to brighten up the alloy. It's pretty clean now. Steel wool?
double ugly
05-20-2007, 01:10 PM
MT
Don't use steel wool. The wool leaves micro pieces and fibers on the surface that soon rust.
A beautiful car, precisely assembled. Unfortunately I don't fit. Sold it after four hundred miles. Well, at least now I know a Cobra is not a car I can own.
05-20-2007, 01:32 PM
Double Ugly,
So what did you end up using to clean your trans case?
05-20-2007, 02:13 PM
az
I used to use WD 40 on my magnesium alloy transaxles years ago. This is aluminium alloy but I tried it and its cleaning up nicely. What didn't clean up I tried brake cleaner. It didn't work on the tougher areas so I'll try carb cleaner (carefully). I also may use woodz idea of S100 if I can find it locally. If it's as good as he says (I'm sure it is) it would be handy to have around.
double ugly
05-20-2007, 02:14 PM
Il
John, The reason I suggested the S100 is because it cleans the pores in the aluminum and makes it look brand new. It only needs a litlle brushing with a soft bristle brush and washes off( and is neutralized) with water. I buy it by the gallon and am trying to locate a source for a 55 gallon drum of it.
WDZ
05-20-2007, 02:38 PM
OR
Cobra Make, Engine: Old ('93)CMC kit, SB ford
Try one of the numerous alloy wheel cleaner sprays.
05-20-2007, 03:19 PM
az
I'll search for some S100 ASAP. The tranny is close to new but going into an incredible replica and I want it to be as close to perfect as possible as possible.
double ugly
05-20-2007, 03:30 PM
OR
Cobra Make, Engine: SPF #2450, Roush 342RE
I'd start with this link...
http://www.s100.com/
Good luck,
Ivan
Forget the health food...I need all the preservatives I can get !!!
05-20-2007, 04:50 PM
Az
Eagle "etching Wheel cleaner"
05-20-2007, 04:55 PM
Beam Me Up Scottie
MA
Castrol super clean is fantastic cleaner, except it should not be used to clean aluminum parts.
Its not available in Calif.
Warren
05-20-2007, 07:50 PM
That Castrol Super Clean is good stuff, but be careful on the skin, it peeled and chaffed mine. Took days to get back to normal and a lot of handcream...
