SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-28-2007, 06:42 PM
Tony Radford's Avatar
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Default Ever seen this in a Toploader?
Third and forth gear disapeared. Now I see why.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
Old 07-28-2007, 06:46 PM
wtm442's Avatar
Beam Me Up Scottie
Too much torque. Suggest you install a small block .... maybe a V-6
Warren
Old 07-28-2007, 08:52 PM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
Original 40 year old part, won't happen with a ner shaft.
" It ain't no big deal"
Old 07-29-2007, 05:54 AM
Tim, I took it back to the place that built it originally. The main shaft was replaced in '98, so it only has 22K miles on it. Warren, it IS a small block. Oh well, I guess it can happen again because I don't plan on backing off.
Old 07-29-2007, 06:34 AM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
I can't see the ends where it's snapped, but from the angle of the pic it appears that it had a crack that existed and finally failed all the way through. When the part was replaced was it with a brand new part or a good used one?? I would suggest having the replacement magnafluxed to catch any existing cracks/flaws before assembling.
WDZ
Old 07-29-2007, 12:29 PM
Rick Parker's Avatar
Metal Fatigue, it can happen to the best.
Rick
