SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 08-11-2007, 07:27 AM
vettestr's Avatar
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Back to ya 2245,
I agree the donor route is a possible and best if using an engine with all the ECM or computer management needed. An important point to those not needing all the ECM support is a donor 5 or 6 speed will now need to be modified at a fairly high level (for use with a carb'd or aftermarket injection engine).
Factory tranny will have an annoying up shift feature, electronic speedo, possible input spline count dictating clutch assem. The clutch assem. means no aftermarket scatter shield or easy interchange and limits to the use of internal Hyd. throw out brg. We use an external Hyd. slave that makes many things a bunch better IMHO. You will need a reverse lockout electrical supply or sw on either but no biggie. A shortened drive shaft and rear tranny X member will need to be fab'd again no big deal for our chassis. I question ease in many other applications that were made for the TINY 4 speeds by comparison. A bit tongue in cheek but its girth and length was close in our car and we are 8' longer and 5" wider than the original Cobra.
The GM aftermarket Tremec or the 011 is a builders dream with all the above addressed for easy install. I put the 6 speed in my own driver even though I was not sure I needed 2 overdrives. The 011 does have modified ratios as well and is PERFECT for use with like 3:55 to 4:11 gears. Unless at highway cruise speed I do not use 6th but when needed it drops RPM down to like 2k at speed.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
