SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 09-30-2007, 06:04 AM
Cobra Make, Engine: SPF 2682, Roush 427
Default Tremec electric speedo connector?
Has anyone figured out what kind of connector is needed for the Tremec TKO-600's electric speedometer output?
Chet
Old 09-30-2007, 08:37 AM
anicholas's Avatar
Cobra Make, Engine: Kirkham FIA
Default Tremec TKO 600 Elec. Speedo connector
Chet,
Contact Don Walsh at D&D in Detroit. (248) 735-6220.
If your tranny is a Ford bolt pattern, the plug will be "D" shaped female.
If you have a Chevy bolt pattern as I do to fit a Tilton bellhousing, the two wire plug will be an oval male. $29 each.
A. Nicholas
KMP 517
Pushing on the pull door of reality.
Old 09-30-2007, 08:56 AM
Thanks, I have the Ford. Now let me think. I have a hole with 2 "solid" pins sticking up inside the hole. Bisexual? I'll call D&D Monday.
Chet
Old 09-30-2007, 10:43 AM
chet, I am working on the same issue. I have info you may need. Give me a call to discuss. 225-223-5330
Doug
No body cares what you know until you they know that you care.
Old 09-30-2007, 01:30 PM
Roscoe's Avatar
I have a 3550 and used standard Ford connectors for my Autometer elec speedo. Much cheaper than anyone else. Don't know if it's the same.
You can also try contacting Tremec direct. Web site is http://www.ttcautomotive.com/English/home/home.asp
Roscoe
Roscoe
