SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 10-05-2007, 04:12 PM
Dangerous Doug's Avatar
Cobra Make, Engine: ERA 289 FIA #2108
I may be stating the obvious, but I'd say pull the driveline and test it again. If you have the noise, it's likely in the transmission.
If you don't, then check the rear differential for play, and check the bearings on the u-joints.
I'd be interested in the final prognosis.
DD
Dangerous Doug
"You're kidding, right?"
Old 10-05-2007, 08:04 PM
DDoug - Do you mean run it up in the air without the driveshaft attached to the geabox? What would that show? There wouldnt be much/any load on the tailshaft of the box?
There is some rear differential play. However, I have swapped the diff for a different center and the noises still sound exactly the same. This is a video of the car with the handbrake on with wheels on the ground
http://www.youtube.com/watch?v=aqnbEiv1y5M
There didnt seem to be excessive backlash in the crown & pinion when I had it out.
Linesligner - Thanks for the PM. I am about 30 days out of my 90 day warranty, partly due to the fact that when the box was shipped (to Australia) it was shipped without a x member which lead to me having to fab it up after work .
Clois Harlan - Its a solid axle setup in a 68 mustang, rather than a cobra. The mounting bracket appears to be ok and the box wasnt really moving when it was making all that noise
strictlypersonl - I'll try that today.
Old 10-08-2007, 04:27 AM
I did a check to see if the yoke engagement was having an effect anyway. I unbolted the drive shaft from the diff and checked the play in the gearbox at various engagement depths - see this video
http://www.youtube.com/watch?v=P9w_dXOhOSs
I checked the play in 2nd gear in that video. It seems like there might be play in the gear set, and that the play was the same regardless of engagement depth. I have heard that some new tremecs may have been shipped with incorrect shimming... my research continues....
