Old 03-17-2008, 01:16 PM
Dangerous Doug's Avatar
Default 26 spline clutch disc for TKO-600?
TKO-600's have a 26 spline input shaft. Ford Racing nicely points out the need to use a 26 spline clutch disc, but offers no such part.
Where do I get a 26 spline clutch plate for a TKO-600?
Dangerous Doug
"You're kidding, right?"
Old 03-17-2008, 01:19 PM
McLeod, Centerforce, they all offer them -- just give them a call.
Old 03-17-2008, 02:35 PM
lineslinger's Avatar
This company has been very helpful to my needs, good analysis, patient, fairly quick shipping. http://www.thedrivenman.com/
Also there is member in here, jimig@standardtransmission.com who is knowledgeable and very helpful.
Old 03-17-2008, 02:40 PM
Burgs's Avatar
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
It's a GM disc.
Old 03-17-2008, 04:17 PM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
i dont know if this helps, but i bought a ram aluminum flywheel from mike forte from fortes parts connection part number 2519 he has ram drill them out for the chevy pressure plate and i purchased a a ram clutch kit part number 98764, he swaps out the chevy throw out bearing for the ford unit and i use the ford fork with an extender on the end for the cable for proper alignment.
Old 03-17-2008, 06:05 PM
Dwight's Avatar
I have bought several trannies, bell housing, etc., from D&D. Best price and great service!
Give them a call.
http://www.ddperformance.com/
Dwight
Old 03-17-2008, 06:53 PM
Cobra Make, Engine: ERA 427SC FMS 351W
Default Got 26 spline disk and reused good pressure plate
After taking out my old 3550, I saw that I had a little used, good FMS pressure plate made by Centerforce. So I researched the Ford Racing Catalog and found that the same dual friction disk was part number FMS-M-7550-T302. I ordered ths disk (only) from Summit. I installed it and have had no problems with my new disk and TKO600.
I purchased my TKO from Jimi at Standard Gear. He was very helpful.
Old 03-18-2008, 09:34 AM
Jimi G's Avatar
Originally Posted by Burgs View Post
It's a GM disc.
Bingo, just get the same size disk for a GM with 26 spline, if you can't find anything locally let me know I can get you fixed up. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
