Old 10-07-2008, 06:42 AM
rwall49's Avatar
Cobra Make, Engine: HM Ford 351w
Default Need advice on Tremec Transmission
Guys,
Transmission experts. When should I change the transmission oil in my Tremec. Its new and I wondered how many miles can be put on it before my first oil change. I dont drive it hard, well maybe I punch it once in a while just for a thrill, but seriously I have driven it with caution cause you never know what little problems you might come up with. I have over 300 miles on the car right now.
Old 10-07-2008, 07:11 AM
If you are driving it gently, with only an occasional punch, the transmission oil will still be fine after you're dead and gone and your kids are then speed shifting your baby at 6000RPM. Make them change it then.
Old 10-07-2008, 08:23 AM
jwd's Avatar
jwd jwd is offline
The Tremec dealer I got mine from recommended the first 500 miles using ATF then change to GM synchromesh.
Old 10-07-2008, 08:38 AM
From the Tremec TKO Installation Tips. http://www.ttcautomotive.com/English...ps_117_117.pdf
We recommend GM synchromesh part # 12345349, or Dexron III / Mercon Spec ATF fluid for all TKO transmissions.
Maintenance
Recommended oil change intervals should be based on specific usage. In most cases a “fill for life” is adequate, while in severe applications such as drag racing, or road racing a more frequent fluid change should be prescribed. Excessive heat will cause most fluids to breakdown and ultimately cause damage to the transmission.
Old 10-07-2008, 08:57 AM
jwd's Avatar
jwd jwd is offline
I tend to lean on the side of over maintenance. When I did the initial change, there were definately tiny metal particles from the break in.
http://www.5speedtransmissions.com
Q: What is the proper break-in procedure for a TREMEC TR-3550/TKO 5sp?
A:
Put 3qt of good quality ATF (Auto Transmission Fluid) (Dexron) into the transmission. Pour in through shifter mount, or through one of the top plates. You can use the fill plug on the side of the transmission also (afterall, that's what it's for!). It's just easier to pour it in from the top if you can.
Put car on jacks, run the transmission up and down through all gears repeatedly for 15 minutes. This will allow the gears to break in properly (yes, with the engine running)
After 500-700 miles, drain the ATF, and put in 3qt of the GM Synchromesh fluid, the part number is 12345349. If it's a race car only, then switch to the GM Synchromesh after the initial break-in.
Don't use synthetic lube for 6000-8000 miles. In fact, we don't recommend synthetic, just stick with the GM Synchromesh.
Old 10-07-2008, 09:32 AM
Those are special oblong ball bearings for increased gear lubrication. Hopefully you saved them so you can put them back in.
Old 10-07-2008, 09:57 AM
Got the Bug's Avatar
Maintenance
Great info! I like that kind of maintenance schedule.
Doug
Old 10-07-2008, 10:16 AM
RodKnock's Avatar
If you have the time, then I would definitely change it every 2 years +/-
Old 10-07-2008, 11:22 AM
rwall49's Avatar
Thanks guys for the info
Old 10-07-2008, 12:35 PM
rattlesnakepete's Avatar
Cobra Make, Engine: Lonestar 427 Comp. 351W
I had the very same question with my 3550 which was ten years old with 8000 miles on it. I drained and replaced the GM synchromesh oil and sent the old stuff in for analysis. They reported high wear metals but said that was normal for a new transmission. They also reported 1.4% insoluables ( sludge) which they said was high. The attributed this to aging of the oil.
Physically the old oil was much darker and thicker then the new stuff.
I have been taking samples on all my cars when I change oil. It has proved useful. For example I had some head work done which require me to remove and reinstall the heads. The oil analysis picked up small quanties of stuff they said likely came from antifreeze. I started looking and sure enough I was getting a little leakage out of the head gasket. I retorqued the heads, ran it for a while and sent in another sample. No indications of leaking so far.
Another good example is my dodge truck. The oil analysis found very high bearing material counts. I have owned this truck since new. Time to consider getting another.
Rule of thumb: Never buy a used car from a guy that has his oil analyzed. He may know something you do not!
For Sale: 1994 dodge truck.......
Way to go Roscoe
Old 01-04-2009, 05:17 PM
Hi rattlesnake,
The TKO shift lugs have dark gray grease on them from the factory. Just a few warm up cycles (less than 100 miles) and the grease all melts away and discolors the oil so it looks dirty.
This is the way the new oil looks so dirty on a new gearbox.
Mike Forte
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
